Re: oxygenated fuel
[Re: W7 Duster]
#205410
01/26/09 09:46 PM
01/26/09 09:46 PM
Posts: 437 south central pa
bdaz smblk
south central pa
You can leave it in the tank but put a cap on the vent if it's going to set for awhile so it don't evaporate.I run the q-16 and thats all I do other than jetting carb up 4 jet sizes.
3120lb, small block, 10.5" tire, NA, through exhaust, full int, WITH 83/4 REAR, 9.0 at 150mph
Re: oxygenated fuel
[Re: bonefish]
#205416
01/27/09 10:39 AM
01/27/09 10:39 AM
Posts: 8,165 Left Coast
BobR
Left Coast
i checked the VP website ,didnt give any specific storage precautions for the oxygenated fuel,i was just wondering cause iv worked so hard to get this carb dialed in i didnt want to go through it all over.i am runnin a new combo so i may have to doit anywho.
It says right on the Q16 can to drain it between races. That's exactly what we do.
Re: oxygenated fuel
[Re: MegaDart]
#205417
01/27/09 11:22 AM
01/27/09 11:22 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
bonefish, I have 4.5gal of c12 that I can't use, I paid $50 for it would you like to buy it??
thanks,if you lived around the corner id take ya up on it,i just gave away 5 gals. of c-16 cuase i needed my jug. were getting some people together right now for a group by on drums if you want to put your name on the list ill give ya the shops # but you have to buy 30 or 55 gal. drums.last time i saved about 2 sumthin a gal. and had to buy the barrel but i got the barrel now so it should be even better.
Re: oxygenated fuel
[Re: bonefish]
#205418
01/27/09 01:30 PM
01/27/09 01:30 PM
Posts: 6,314 The Swamp
MegaDart
The Swamp
bummer, I would traded you.
