crank pulley spacer #205390
01/26/09 08:54 PM
01/26/09 08:54 PM
KY
juicedcuda Offline OP
KY
I the crank pulley spacer necessary with the mancini front motor plate or does it depend on your alternator setup?
And does anyone sell a spacer that will work besides mancini?
1970 Plymouth 'Cuda 1970 Plum Crazy "Gold Duster" 1973 Gold Duster
Re: crank pulley spacer [Re: juicedcuda] #205391
01/26/09 10:50 PM
01/26/09 10:50 PM
AndyF Offline
AndyF  Offline
The spacer is needed if you are going to run a stock type water pump and you want the pulleys to line up.
Re: crank pulley spacer [Re: AndyF] #205392
01/27/09 01:33 AM
01/27/09 01:33 AM
KY
KY
excellent. so electric w/p = no spacer needed.
