Edelbrock Performer Carburetor Secondary Main Question #2052926
04/12/16 05:42 PM
04/12/16 05:42 PM
Louisiana
duckblind Offline OP
Louisiana
I am trying to determine if my edelbrock performer carb is plugged up. I have broken in my engine finally so was able to actually step on the gas pedal a good bit to see how the engine would perform after the rebuild. When I stepped on it the car did ok but it didn’t seem like the engine was getting enough gas. My main question is….when the engine is not running, should I be able to see gas flow out of the top jets in the 3rd and 4th barrel? I did not see any when I pushed the throttle all the way back. I believe I read that the little butterfly valves had to be all the way open for gas to flow out so I opened them with a screwdriver and pushed the throttle back and still did not see gas.
Thanks for any opinion.
Re: Edelbrock Performer Carburetor Secondary Main Question [Re: duckblind] #2052941
04/12/16 06:10 PM
04/12/16 06:10 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
No you will not see gas in the secondaries without the engine running. Gas only flows out of there when the engine is running and the throttle is open far enough to allow the vacuum of the engine to draw fuel.
Re: Edelbrock Performer Carburetor Secondary Main Question [Re: duckblind] #2052964
04/12/16 06:46 PM
04/12/16 06:46 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Engine needs to be running and under load.
If you have an old cell phone or one you don't care about much, you could tape it to the bottom of the hood above the carb (with filter off) and video the carb while driving and going WOT?
Re: Edelbrock Performer Carburetor Secondary Main Question [Re: duckblind] #2052966
04/12/16 06:49 PM
04/12/16 06:49 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Edelbrock has an owners manual that does a pretty good job explaining things.
http://www.edelbrock.com/automotive/misc/tech-center/dl/carb-owners-manual.pdf
Don't be the exception.
