Loose pinion bearing race
#2052059
04/11/16 07:22 PM
04/11/16 07:22 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
I am finally putting together a Dana 60 for my charger out of a truck and I finally got my tubes cut and new ends welded on so I brought it to my guy to set up the gears and he called me and said the pinion bearing race has .009 clearance and it looks like the race spun in the case. I was told JB weld the race in but the guy setting it up said he didn't really want to do it that way. He said he found a race with the same inside measurement and a little larger on the outside and can have a guy machine the housing for the larger race. Going to cost me $200 to have it machined to fit the new race. Seems like this would be a better way to do the job correctly. What does Moparts think?
67' charger 499 RB
10.57 at 127
Re: Loose pinion bearing race
[Re: dragram440]
#2052082
04/11/16 07:51 PM
04/11/16 07:51 PM
Posts: 2,118 Byron, NY
W.I.N. Racing
Byron, NY
Spend the Money and fix it right...JB weld is NOT the answer.(seldom is) which of the two pinion bearings is it?
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: W.I.N. Racing]
#2052094
04/11/16 07:59 PM
04/11/16 07:59 PM
dartman366
Mt. Vernon, Ohio
I would say have it done, you got time and money in it now ,why junk it when it is salvageable and nobody will ever know.
[Re: dragram440]
#2052101
04/11/16 08:10 PM
04/11/16 08:10 PM
Posts: 75,092 A Banana Republic near you.
JohnRR
Spend the money and fix it right, JB weld is not the fix.
With that much clearance I'm going to guess you bought this housing stripped down already , otherwise that bearing race would have just fallen out of the case when you flipped it over to remove it.
[Re: JohnRR]
#2052178
04/11/16 09:35 PM
04/11/16 09:35 PM
Posts: 20,198 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I say fix it right. If it spins, gets hot, and locks up the rearend at speed it will be money well spent. Things can get UGLY real fast.
[Re: dragram440]
#2052194
04/11/16 09:57 PM
04/11/16 09:57 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Machining the housing IS the right way to fix it. Get the part number of the new bearing so that if you need one down the road, you will have a reference.
[image][/image]
[Re: Cab_Burge]
#2052235
04/11/16 10:22 PM
04/11/16 10:22 PM
Posts: 20,198 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I'm betting the other way. Most machine shops now can get the tolerances closer than that factories did 30 years ago. These machines in the right hands are crazy accurate. Maybe that's why it spun.
[Re: dragram440]
#2052337
04/11/16 11:37 PM
04/11/16 11:37 PM
dragram440
bigfork mn
I am having it machined. Hopefully it's done correctly. I have to much in to the housing already having the main caps fitted and having it narrowed and welded. The guy setting it up really stressed on the force on the bearing and race was to much in a race car for jb weld.
67' charger 499 RB
10.57 at 127
[Re: dragram440]
#2052344
04/11/16 11:43 PM
04/11/16 11:43 PM
sgcuda
Indexing for the proper center isn't a problem these days. No different than a proper line bore, lifter indexing or any other block work, just on a smaller piece.
[image][/image]
[Re: sgcuda]
#2052518
04/12/16 02:08 AM
04/12/16 02:08 AM
Posts: 8,344 fredericksburg,va
cudaman1969
fredericksburg,va
Indexing for the proper center isn't a problem these days. No different than a proper line bore, lifter indexing or any other block work, just on a smaller piece. How good were these housings machined back then? I would say there was a good deal of tolerance on a mass produced housing anyway. Be a good time to really blueprint that housing to exact specs.
[Re: cudaman1969]
#2052806
04/12/16 02:58 PM
04/12/16 02:58 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
Indexing for the proper center isn't a problem these days. No different than a proper line bore, lifter indexing or any other block work, just on a smaller piece. How good were these housings machined back then? I would say there was a good deal of tolerance on a mass produced housing anyway. Be a good time to really blueprint that housing to exact specs. The Dana housing that I built for the Ramcharger had that issue and it was machined by the differential shop that assembled that one with the spool. They do a lot of race car diffs. The Dana that I built for the Daily Driver had already been overhauled properly so all I had to do there was to cut one tube and shorten and respline one axle. All the bearings and brakes were new and it came with 4.10s and a PowerLock.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: dragram440]
#2052957
04/12/16 06:37 PM
04/12/16 06:37 PM
dragram440
bigfork mn
The guy I have set up my gears is very picky about his work and doesnt want me to have a problem down the road. I looked into all the different loctite race adhesives and primers. I also talked to a very reputable person on here and they said to just used JB weld put some on both mating surfaces of the race and housing and I wouldn't have any problems. The new race is coming on Friday and hopefully it will be done by the end of the weekend.
67' charger 499 RB
10.57 at 127
