Loose pinion bearing race #2052059
04/11/16 07:22 PM
04/11/16 07:22 PM
bigfork mn
dragram440 Offline OP
bigfork mn
I am finally putting together a Dana 60 for my charger out of a truck and I finally got my tubes cut and new ends welded on so I brought it to my guy to set up the gears and he called me and said the pinion bearing race has .009 clearance and it looks like the race spun in the case. I was told JB weld the race in but the guy setting it up said he didn't really want to do it that way. He said he found a race with the same inside measurement and a little larger on the outside and can have a guy machine the housing for the larger race. Going to cost me $200 to have it machined to fit the new race. Seems like this would be a better way to do the job correctly. What does Moparts think?
67' charger 499 RB 10.57 at 127
Re: Loose pinion bearing race [Re: dragram440] #2052082
04/11/16 07:51 PM
04/11/16 07:51 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Spend the Money and fix it right...JB weld is NOT the answer.(seldom is)
which of the two pinion bearings is it?
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Loose pinion bearing race [Re: dragram440] #2052092
04/11/16 07:56 PM
04/11/16 07:56 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Theres a lot of force on the pinion race and bearing. You want that to remain as true as possible to keep pinion gear deflection down as low as possible. .010 is to much slop and JB weld will be to Soft of fix. Fine maybe for a street car, and I mean Street as in just a driver.
But for a performance build do the correct fix. Also, how are the carrier races, seen them egg shaped and blown out.
Re: Loose pinion bearing race [Re: W.I.N. Racing] #2052094
04/11/16 07:59 PM
04/11/16 07:59 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I would say have it done, you got time and money in it now ,why junk it when it is salvageable and nobody will ever know.
Re: Loose pinion bearing race [Re: dragram440] #2052101
04/11/16 08:10 PM
04/11/16 08:10 PM
A Banana Republic near you.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
Spend the money and fix it right, JB weld is not the fix.
With that much clearance I'm going to guess you bought this housing stripped down already , otherwise that bearing race would have just fallen out of the case when you flipped it over to remove it.
Re: Loose pinion bearing race [Re: JohnRR] #2052178
04/11/16 09:35 PM
04/11/16 09:35 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I say fix it right. If it spins, gets hot, and locks up the rearend at speed it will be money well spent. Things can get UGLY real fast.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Loose pinion bearing race [Re: dragram440] #2052189
04/11/16 09:50 PM
04/11/16 09:50 PM
gregsdart Offline
gregsdart  Offline
I agree. Do it right, and you will sleep well too.
Re: Loose pinion bearing race [Re: dragram440] #2052194
04/11/16 09:57 PM
04/11/16 09:57 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Machining the housing IS the right way to fix it. Get the part number of the new bearing so that if you need one down the road, you will have a reference.
[image][/image]
Re: Loose pinion bearing race [Re: dragram440] #2052224
04/11/16 10:15 PM
04/11/16 10:15 PM
I would throw that housing away and get a known good one to start with up New or used shruggy Not many machine shops out there will be able to get the new center of the bearing race machined correclty in relation to the other one work shruggy
Good luck thumbs
Re: Loose pinion bearing race [Re: Cab_Burge] #2052235
04/11/16 10:22 PM
04/11/16 10:22 PM
PA.
"Little"John
"Little"John
PA.
I'm betting the other way. Most machine shops now can get the tolerances closer than that factories did 30 years ago. These machines in the right hands are crazy accurate. Maybe that's why it spun.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Loose pinion bearing race [Re: Cab_Burge] #2052238
04/11/16 10:23 PM
04/11/16 10:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Good luck thumbs
iagree.. you lost enough already in this housing..
buy another... cheaper in the long run
wave
Re: Loose pinion bearing race [Re: dragram440] #2052337
04/11/16 11:37 PM
04/11/16 11:37 PM
bigfork mn
bigfork mn
I am having it machined. Hopefully it's done correctly. I have to much in to the housing already having the main caps fitted and having it narrowed and welded. The guy setting it up really stressed on the force on the bearing and race was to much in a race car for jb weld.
Re: Loose pinion bearing race [Re: dragram440] #2052344
04/11/16 11:43 PM
04/11/16 11:43 PM
sgcuda Offline
sgcuda  Offline
Indexing for the proper center isn't a problem these days. No different than a proper line bore, lifter indexing or any other block work, just on a smaller piece.
[image][/image]
Re: Loose pinion bearing race [Re: sgcuda] #2052518
04/12/16 02:08 AM
04/12/16 02:08 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
How good were these housings machined back then? I would say there was a good deal of tolerance on a mass produced housing anyway. Be a good time to really blueprint that housing to exact specs.
Re: Loose pinion bearing race [Re: cudaman1969] #2052806
04/12/16 02:58 PM
04/12/16 02:58 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
The Dana housing that I built for the Ramcharger had that issue and it was machined by the differential shop that assembled that one with the spool. They do a lot of race car diffs.
The Dana that I built for the Daily Driver had already been overhauled properly so all I had to do there was to cut one tube and shorten and respline one axle. All the bearings and brakes were new and it came with 4.10s and a PowerLock.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Loose pinion bearing race [Re: dragram440] #2052869
04/12/16 04:09 PM
04/12/16 04:09 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
If the bore is not physically out of round then machine power or manually knural the bore and install the race with sleeve seal.This can be done for less than $50.If you machine for a different race record that race p/n on the housing for future rebuilds.
Re: Loose pinion bearing race [Re: dragram440] #2052957
04/12/16 06:37 PM
04/12/16 06:37 PM
bigfork mn
bigfork mn
The guy I have set up my gears is very picky about his work and doesnt want me to have a problem down the road. I looked into all the different loctite race adhesives and primers. I also talked to a very reputable person on here and they said to just used JB weld put some on both mating surfaces of the race and housing and I wouldn't have any problems. The new race is coming on Friday and hopefully it will be done by the end of the weekend.
