Where did you put your MSD box ? #2051256
04/10/16 07:48 PM
04/10/16 07:48 PM
mikeb Offline OP
mikeb  Offline OP
Just curious where is a good location to mount the MSD box under the hood the inside wont work the firewall is busy just curious. thanks Mike
Re: Where did you put your MSD box ? [Re: mikeb] #2051275
04/10/16 08:15 PM
04/10/16 08:15 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
I had the MSD on my 71 RR in the cowl
Abe Lincoln
Re: Where did you put your MSD box ? [Re: dart4forte] #2051288
04/10/16 08:34 PM
04/10/16 08:34 PM
IN
ahy Offline
ahy  Offline
IN
Mine is mounted to the battery tray with battery in trunk. There is a vent in the cowl there to help keep it cool.
Re: Where did you put your MSD box ? [Re: mikeb] #2051302
04/10/16 08:56 PM
04/10/16 08:56 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
On the underside of the battery tray.
Re: Where did you put your MSD box ? [Re: mikeb] #2051313
04/10/16 09:06 PM
04/10/16 09:06 PM
Morrow, OH
markz528 Online content
markz528  Online Content
Morrow, OH
On my 67 Coronet I mounted it under the horns. Was pretty well hidden.
Re: Where did you put your MSD box ? [Re: mikeb] #2051317
04/10/16 09:10 PM
04/10/16 09:10 PM
Harm City Md.
Dan Halen Offline
Dan Halen  Offline
Harm City Md.
Under the battery tray.
Re: Where did you put your MSD box ? [Re: John_Kunkel] #2051355
04/10/16 10:07 PM
04/10/16 10:07 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Same here on 70 E Body. Don't never have to see it.
Re: Where did you put your MSD box ? [Re: mikeb] #2051387
04/10/16 10:32 PM
04/10/16 10:32 PM
Which model box? If a 6 or one of those type under the battery tray is pretty common up If it is one of the seven race boxes I've mounted them on the inner fenderwell and on the engine side of the radiator core support thumbs Make sure to try and keep both types away from moisture and excessive heat.
Re: Where did you put your MSD box ? [Re: mikeb] #2051397
04/10/16 10:46 PM
04/10/16 10:46 PM
mikeb Offline OP
mikeb  Offline OP
I had it on the radiator support but I am putting a 26 inch wide radiator and need to move it so i was kind of curious where there is a good spot. I have to test fit the radiator to see the room thanks. Mike
Re: Where did you put your MSD box ? [Re: mikeb] #2051728
04/11/16 11:22 AM
04/11/16 11:22 AM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
I put mine under the dash. I am not sure I would do it again. Its a bit noisy and, since its red, sticks out some. But, I wanted it out of the heat and any rain if I happen to get caught out in it.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: Where did you put your MSD box ? [Re: mikeb] #2051739
04/11/16 11:48 AM
04/11/16 11:48 AM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
I mounted mine on the firewall of my Challenger.
Re: Where did you put your MSD box ? [Re: YO7_A66] #2051763
04/11/16 12:34 PM
04/11/16 12:34 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Under the battery tray here as well. Really convenient for wiring on a BB. I mounted the dial for the Rev limiter to the frame rail right below it. Unless you're really looking hard you never see it!
Re: Where did you put your MSD box ? [Re: mikeb] #2051766
04/11/16 12:40 PM
04/11/16 12:40 PM
Ohio
lockjaw-express Offline
Ohio
I gutted out the glove box and put it in there, and put the Ron Francis fuse/relay panel in with it. I did wire it into the stock wiring harness and fused more items.
BR, Mark
Re: Where did you put your MSD box ? [Re: lockjaw-express] #2051789
04/11/16 01:09 PM
04/11/16 01:09 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
MSD 6al is in glove box on an F body here.
Re: Where did you put your MSD box ? [Re: mikeb] #2051819
04/11/16 01:43 PM
04/11/16 01:43 PM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
I mounted mine in the passenger compt. on the firewall
Re: Where did you put your MSD box ? [Re: moparsquid] #2052040
04/11/16 06:58 PM
04/11/16 06:58 PM
Westchester, NY
JM67RT Offline
JM67RT  Offline
Westchester, NY
Re: Where did you put your MSD box ? [Re: mikeb] #2052061
04/11/16 07:24 PM
04/11/16 07:24 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
To the right of the radiator, follow the coil wire.
Re: Where did you put your MSD box ? [Re: mikeb] #2052095
04/11/16 07:59 PM
04/11/16 07:59 PM
California
mickm Offline
mickm  Offline
California
On the front of the heater core in the passenger compartment. Easy to get to the wires and changing the rev limiter, but completely hidden from view.
Re: Where did you put your MSD box ? [Re: mickm] #2052193
04/11/16 09:56 PM
04/11/16 09:56 PM
I put my Might Sputter and Die box back on the shelf
Re: Where did you put your MSD box ? [Re: mikeb] #2052231
04/11/16 10:19 PM
04/11/16 10:19 PM
Richmond, Indiana
19swinger70 Offline
19swinger70  Offline
Richmond, Indiana
Passenger side inner fender.
1970 340 swinger. sublime
1967 barracuda fastback BB
55 Plymouth Project
