m/t pro bracket radials #2050657
04/09/16 10:37 PM
04/09/16 10:37 PM
okla.
sam64 Offline OP
sam64  Offline OP
okla.
I put a set of pro bracket radials on my car and it doesn't like them I don't think.first pass I heated them about like I would my bias slicks and it blew the the tires at the hit,came back did a shorter burnout same deal.both times I lifted and stabbed it and it stayed hooked.i foot brake and stage at 2,000 conv flashes 3,800,first 2 passes were 19 psi dropped to 17.5 and left at idle it hooked and had best 60ft ever.came back and did same launch and blew the tires off.argh!!so I guess I am looking for suggestions,go back to bias or start spending money on suspension. currently it has super stock springs, c.e. shocks,tubular upper control arms with heim ends,heim end strut rods,90/10 front shocks.car normally 60ft 1.50,when it did hook today it went 1.46.thanks,Sam.
Re: m/t pro bracket radials [Re: sam64] #2050670
04/09/16 10:49 PM
04/09/16 10:49 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
DA shocks on all fours should help a lot.
Yeah, it's got a smallblock.
Re: m/t pro bracket radials [Re: sam64] #2050687
04/09/16 11:17 PM
04/09/16 11:17 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Time for suspension . I use the 28x10.5 PBR . Only ever run radials on my Satellite . Small block front bars with single sdjust qa1 front shocks , xhd rear springs with caltracs and rancho 9 way shocks . Fronts full loose rear shock 1 or 2 loose from full tight on extension . 18-18.5 psi .
Actually turned them wednesday at a no prep street meeting , dropped rear tyre to 18 lossened rear shock 1 click and it hooked .i am leaving soft at around 2000/2200 .
Oh yeah good burn out no John Force . I hold 3/5seconds once i see smoke in rear mirror and drive it out . Too small burn out it will turn .
This is with the PBR and Hoosier 275 radial
Good luck
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: m/t pro bracket radials [Re: tex013] #2050704
04/09/16 11:41 PM
04/09/16 11:41 PM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
18psi and a good tire gauge....They either dead hook, or go up in smoke.
Re: m/t pro bracket radials [Re: Dragula] #2050781
04/10/16 01:57 AM
04/10/16 01:57 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
All the more reasons why I run bias plys although some have good luck w/em.............
Re: m/t pro bracket radials [Re: Thumperdart] #2050849
04/10/16 04:42 AM
04/10/16 04:42 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I use the Hoosier 30 x 9 radial slicks myself. I found that as long as I stage in the grove where all the cars launch it always hooks fine. My suspension is basically all stock other then 3400 SS springs and Comp 90/10 front shocks. Rear shocks are just the longer MP shocks. My 60's are low 1.50's as its usually from 1.50 to 1.52 with a 1.50 best. But is is very consisdent for a radial slick on a car I drive to the track. The last two times at the track all my passes were all within 4 hundreths of each other all day long. Ron
Re: m/t pro bracket radials [Re: sam64] #2050959
04/10/16 12:13 PM
04/10/16 12:13 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Anyone ever did a back to back comparison on these two types of slicks?
Re: m/t pro bracket radials [Re: sam64] #2050986
04/10/16 12:56 PM
04/10/16 12:56 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
I would try lowering the pressure. I run a Hoosier radial slick. Started with 18#, best 60' I got was 1.24 with 13#. U have to experiment with tire pressure at different tracks.
Re: m/t pro bracket radials [Re: racerx] #2051255
04/10/16 07:45 PM
04/10/16 07:45 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
which 2 ?
Tex
New best MPH 130.32
Re: m/t pro bracket radials [Re: racerx] #2051376
04/10/16 10:21 PM
04/10/16 10:21 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
The radial will always be faster if it hooks.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: m/t pro bracket radials [Re: sam64] #2051419
04/10/16 11:08 PM
04/10/16 11:08 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Thaxs thumbs
