m/t pro bracket radials
#2050657
04/09/16 10:37 PM
04/09/16 10:37 PM
Posts: 1,285 okla.
sam64
okla.
I put a set of pro bracket radials on my car and it doesn't like them I don't think.first pass I heated them about like I would my bias slicks and it blew the the tires at the hit,came back did a shorter burnout same deal.both times I lifted and stabbed it and it stayed hooked.i foot brake and stage at 2,000 conv flashes 3,800,first 2 passes were 19 psi dropped to 17.5 and left at idle it hooked and had best 60ft ever.came back and did same launch and blew the tires off.argh!!so I guess I am looking for suggestions,go back to bias or start spending money on suspension. currently it has super stock springs, c.e. shocks,tubular upper control arms with heim ends,heim end strut rods,90/10 front shocks.car normally 60ft 1.50,when it did hook today it went 1.46.thanks,Sam.
Re: m/t pro bracket radials
[Re: sam64]
#2050670
04/09/16 10:49 PM
04/09/16 10:49 PM
Posts: 1,532 off the grid
340B5
off the grid
DA shocks on all fours should help a lot.
Yeah, it's got a smallblock.
[Re: sam64]
#2050687
04/09/16 11:17 PM
04/09/16 11:17 PM
Posts: 2,460 Sydney,Australia
tex013
Sydney,Australia
Time for suspension . I use the 28x10.5 PBR . Only ever run radials on my Satellite . Small block front bars with single sdjust qa1 front shocks , xhd rear springs with caltracs and rancho 9 way shocks . Fronts full loose rear shock 1 or 2 loose from full tight on extension . 18-18.5 psi . Actually turned them wednesday at a no prep street meeting , dropped rear tyre to 18 lossened rear shock 1 click and it hooked .i am leaving soft at around 2000/2200 . Oh yeah good burn out no John Force . I hold 3/5seconds once i see smoke in rear mirror and drive it out . Too small burn out it will turn . This is with the PBR and Hoosier 275 radial Good luck
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: Dragula]
#2050781
04/10/16 01:57 AM
04/10/16 01:57 AM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
18psi and a good tire gauge....They either dead hook, or go up in smoke. All the more reasons why I run bias plys although some have good luck w/em.............
[Re: racerx]
#2051255
04/10/16 07:45 PM
04/10/16 07:45 PM
tex013
Sydney,Australia
Anyone ever did a back to back comparison on these two types of slicks? which 2 ? Tex
[Re: racerx]
#2051376
04/10/16 10:21 PM
04/10/16 10:21 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Anyone ever did a back to back comparison on these two types of slicks? The radial will always be faster if it hooks.
Brett Miller W9 cnc'd heads STR Chassis fabraction
