Re: TF2 Line and Throttle Pressure Adjustment
[Re: mopowers]
#2051195
04/10/16 06:11 PM
04/10/16 06:11 PM
Posts: 25,977 Rio Linda, CA
John_Kunkel
Rio Linda, CA
These instructions are for the blue line pressure spring, not sure if it's the same with the orange spring.
[Re: mopowers]
#2051305
04/10/16 08:59 PM
04/10/16 08:59 PM
John_Kunkel
Rio Linda, CA
The drill is 3/16" and the latest instructions have the line pressure adjuster seated against the retainer but don't know what spring they use in the latest kits.
[Re: 451Mopar]
#2052654
04/12/16 11:33 AM
04/12/16 11:33 AM
Posts: 3,011 Sac, CA
mopowers
Sac, CA
I think the Monroe book has the size listed for the factory tool used to set the kickdown screw. I looked at the new TF-2 kit, even less info than the older kits had. No mention on adjusting the KD screw, just the pressure regulator adjustment. Exactly! Thank god there's the internet.
[Re: mopowers]
#2052879
04/12/16 04:18 PM
04/12/16 04:18 PM
John_Kunkel
Rio Linda, CA
The very first TF-2 kits set the throttle valve air gap at 1/8", later kits have it at 3/16". Most factory air gaps are around .200".
The dimension of the factory tool is 5/8" but it's used with the valves bottomed out, not as an air gap gauge.
[Re: moparx]
#2053755
04/13/16 05:05 PM
04/13/16 05:05 PM
John_Kunkel
Rio Linda, CA
The adjustment of the throttle valve isn't too critical, as long as there is some air gap with the VB on the bench.
