727 Leaking !! #2049916
04/08/16 06:53 PM
04/08/16 06:53 PM
okla.
O
okie Offline OP
okie  Offline OP
O
okla.
I had my tranny rebuilt, got a new pan and it is still leaking. If you get it a little over full and drive it will it vent are blow the seals out? I think it is coming out of the vent and it was just a little over full. Thanks for any help
Re: 727 Leaking !! [Re: okie] #2049921
04/08/16 07:06 PM
04/08/16 07:06 PM
Zombieland
Car Nut Offline
Car Nut  Offline
Zombieland
Might be leaking out of the shifter seal.
Re: 727 Leaking !! [Re: okie] #2049935
04/08/16 07:22 PM
04/08/16 07:22 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Try running it a little under FULL.
Re: 727 Leaking !! [Re: okie] #2050227
04/09/16 09:24 AM
04/09/16 09:24 AM
okla.
O
okie Offline OP
okie  Offline OP
O
okla.
Every seal has been replaced except the shifter seal, have had 2 different shop work on it and it still leaks. I finally sealed the filler tube and put the new pan on it and it all most stopped but now it is leaking bad again. I know I got it a little over full but I didn't want to remove the pan so I drove it some and I thought it might have been blowing it out the vent. It shows to be a pint low now and seems to have slowed down. gonna drive it a couple hundred miles today so I'll see what it does. I am tired of the leaking
Re: 727 Leaking !! [Re: okie] #2050306
04/09/16 11:29 AM
04/09/16 11:29 AM
Andrewh Offline
Andrewh  Offline
why not replace the shifter seal then?
it is a known leak point.
Re: 727 Leaking !! [Re: Andrewh] #2050499
04/09/16 05:19 PM
04/09/16 05:19 PM
Zombieland
Car Nut Offline
Car Nut  Offline
Zombieland
Very easy to do too, took me less than 15mins. If you want to know how, I can post pictures.
Re: 727 Leaking !! [Re: okie] #2050509
04/09/16 05:39 PM
04/09/16 05:39 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
Does the shift shaft seal sit proud of the case on top? In other words, can you use something larger than the OD of the seal to install it and still have it seat in it's recess?
Re: 727 Leaking !! [Re: okie] #2050534
04/09/16 06:17 PM
04/09/16 06:17 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I would suggest pin pointing the leak(s) before chasing your tail.
whistling beer
Re: 727 Leaking !! [Re: okie] #2050561
04/09/16 07:10 PM
04/09/16 07:10 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
In your OP you state the trans was "rebuilt". Anybody who rebuilds a 727 and doesn't replace EVERY seal isn't really rebuilding it. Demand that whoever did the work replace the shift shaft seal at no charge.
Chances are, if they didn't replace that seal, they probably didn't replace the rear band lever pivot pin O ring either.
Re: 727 Leaking !! [Re: John_Kunkel] #2050575
04/09/16 07:30 PM
04/09/16 07:30 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
HaHaHa!! classic up
Re: 727 Leaking !! [Re: okie] #2050595
04/09/16 08:15 PM
04/09/16 08:15 PM
Andrewh Offline
Andrewh  Offline
http://www.gradeatools.com/Atec-Trans-To...LkgEhoCNzfw_wcB
this will let you do it in the car. one to pull it, and one to push it back in.
you need a big c-clamp to use both.
Re: 727 Leaking !! [Re: John_Kunkel] #2050777
04/10/16 01:53 AM
04/10/16 01:53 AM
Tacoma, Washington USA
Adam71Charger Offline
iagree
I will also add that the 'full' rebuild kit I got for my 727 didn't come with the shifter seal. That's probably what happened at your trans rebuild shop. Never the less, it is part of a rebuild and they should install it for you no charge
Re: 727 Leaking !! [Re: Andrewh] #2050825
04/10/16 03:16 AM
04/10/16 03:16 AM
Zombieland
Car Nut Offline
Car Nut  Offline
Zombieland
I bought the tool for $2, now selling for $14 on eBay, eBay item number:
331806215927.
Re: 727 Leaking !! [Re: John_Kunkel] #2050832
04/10/16 03:32 AM
04/10/16 03:32 AM
Zombieland
Car Nut Offline
Car Nut  Offline
Zombieland
x3
Re: 727 Leaking !! [Re: okie] #2050985
04/10/16 12:53 PM
04/10/16 12:53 PM
okla.
O
okie Offline OP
okie  Offline OP
O
okla.
It wasn't leaking all that bad but now it is really leaking, just got to get it fixed
Re: 727 Leaking !! [Re: Car Nut] #2050990
04/10/16 12:58 PM
04/10/16 12:58 PM
okla.
O
okie Offline OP
okie  Offline OP
O
okla.
Some pictures would be a great help, no rush just when you get a chance. Thanks Ronnie
Re: 727 Leaking !! [Re: okie] #2051019
04/10/16 01:41 PM
04/10/16 01:41 PM
Andrewh Offline
Andrewh  Offline
Re: 727 Leaking !! [Re: okie] #2051025
04/10/16 01:52 PM
04/10/16 01:52 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
The dipstick o ring and selector shaft seal are are common leak points. Another leak point that is commonly overlooked is the pivot pin for the L/R band lever. I have seen a lot of people "rebuild" these transmissions and not replace it. They will just remove the strut and flip the lever out of the way to take the servo out without replacing the o ring. To most it will look like the pan is leaking when fluid is actually coming out of the L/R pin hole in the rear of the case.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: 727 Leaking !! [Re: okie] #2051112
04/10/16 03:54 PM
04/10/16 03:54 PM
Zombieland
Car Nut Offline
Car Nut  Offline
Zombieland
No need to remove the transmission.
Re: 727 Leaking !! [Re: okie] #2051113
04/10/16 03:55 PM
04/10/16 03:55 PM
Zombieland
Car Nut Offline
Car Nut  Offline
Zombieland
cool
