Need to converting 65 b body front drum to disc brakes? #2049015
04/07/16 05:51 PM
04/07/16 05:51 PM
N.Y.
sixpacksteve Offline OP
N.Y.
on what type of a-b-c body car with disc brakes can i use to convert my 65 dodge coronet with drums.
Hell Hath No Fury Like Mine
Re: Need to converting 65 b body front drum to disc brakes? [Re: sixpacksteve] #2049021
04/07/16 05:58 PM
04/07/16 05:58 PM
AndyF Offline
AndyF  Offline
Most any A-B-E body car stuff can be adapted. Easiest to find and work with is the late model A body stuff. Just call up DoctorDiff and get a complete setup.
Re: Need to converting 65 b body front drum to disc brakes? [Re: sixpacksteve] #2049029
04/07/16 06:04 PM
04/07/16 06:04 PM
Andrewh Offline
Andrewh  Offline
though probably long gone by now, m bodies work too.
mine are off of that type of car.
Re: Need to converting 65 b body front drum to disc brakes? [Re: sixpacksteve] #2049049
04/07/16 06:22 PM
04/07/16 06:22 PM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
Once you get spindles from any of the cars listed above you can get the rest from your local parts store. Everything but the spindles you would probably want to replace anyway. And of course Dr diff and others offer complete kits with everything you need.
Re: Need to converting 65 b body front drum to disc brakes? [Re: sixpacksteve] #2049060
04/07/16 06:30 PM
04/07/16 06:30 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Spindles and caliper adapters.
Don't be the exception.
Re: Need to converting 65 b body front drum to disc brakes? [Re: Supercuda] #2049066
04/07/16 06:35 PM
04/07/16 06:35 PM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
Ooops Yep!!
Re: Need to converting 65 b body front drum to disc brakes? [Re: sixpacksteve] #2049344
04/07/16 11:45 PM
04/07/16 11:45 PM
tennessee,usa
mattsmopars Offline
mattsmopars  Offline
tennessee,usa
I used some Aspen front disc brakes on my 65 coronet with a 73 up A body master cylinder. They worked great for me.
Matt
Re: Need to converting 65 b body front drum to disc brakes? [Re: AndyF] #2049388
04/08/16 12:41 AM
04/08/16 12:41 AM
SW CO
HemiSportFury Offline
SW CO
Just finished doing that on my 64. Everything included and new. Pretty simple way to do it for a very fair price IMO.
'64 Sport Fury, 528 Hemi, FiTech EFI, 4-speed, 4.10 Dana 60
'57 Belvedere 2dr sedan, current project in process
'19 Cherokee Trail Hawk Elite
'03 Ram 2500 CTD HO, 6-speed 214,000 miles and still going strong
Re: Need to converting 65 b body front drum to disc brakes? [Re: Supercuda] #2049427
04/08/16 01:57 AM
04/08/16 01:57 AM
AndyF Offline
AndyF  Offline
Spindles are available new (but might not be factory quality). Doctor Diff has repo caliper adapters.
So these days everything is reproduced to do the A body knuckle with 10.78 or 11.75 rotors. The taller (and lighter) FMJ knuckle isn't reproduced so if you want to go the tall knuckle route you have to find originals.
Re: Need to converting 65 b body front drum to disc brakes? [Re: sixpacksteve] #2049439
04/08/16 02:30 AM
04/08/16 02:30 AM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Or get the Scarebird brackets and source the other parts yourself. No need to change spindles.
https://scarebird.com/index.php?route=product/product&path=64&product_id=101
Re: Need to converting 65 b body front drum to disc brakes? [Re: John_Kunkel] #2049499
04/08/16 09:29 AM
04/08/16 09:29 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
...or get the Wilwood Pro Street kit for drum spindles and shave a ton of weight! Aluminum hub, aluminum caliper and easily bolts to existing spindles.
Re: Need to converting 65 b body front drum to disc brakes? [Re: sixpacksteve] #2049525
04/08/16 10:18 AM
04/08/16 10:18 AM
Andrewh Offline
Andrewh  Offline
careful on the scarebird stuff.
if you fill your wheel wells, it will then push the tires out so they stick out past the fenders. if you are on the edge already.
Re: Need to converting 65 b body front drum to disc brakes? [Re: sixpacksteve] #2049542
04/08/16 10:37 AM
04/08/16 10:37 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I had the A body spindles on my 65.Changed them to the taller b body ones I had.Been on for at least 15 years.I run C body disc/drum masters on conversions.Even leavin drums all around we still run the 70 c body masters just drum/ drum.Did my kids 62 300 like that and it went 14 years till he sold the car.The taller spindles I think make alignment better.Rocky
Chrysler Firepower
Re: Need to converting 65 b body front drum to disc brakes? [Re: GY3] #2049707
04/08/16 02:27 PM
04/08/16 02:27 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
The Wilwood kit is the chit!!! But it's the top of the food chain...That's what I have for my 65 Bel II. A little closer to the bottom is the 80's Diplomat stuff. I used it on my 70 Satellite...15K with zero issues... twocents
...FAFO...
Re: Need to converting 65 b body front drum to disc brakes? [Re: John_Kunkel] #2050046
04/08/16 10:26 PM
04/08/16 10:26 PM
N.Y.
N.Y.
i found a 73 dart 4 door donor car w/disc's will i need the control arms?
Re: Need to converting 65 b body front drum to disc brakes? [Re: sixpacksteve] #2050053
04/08/16 10:37 PM
04/08/16 10:37 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
You only need the control arms when installing them on a 67-72 A body. If they're something in decent shape I'd get them too...they'll be easy to sell later.... twocents
...FAFO...
Re: Need to converting 65 b body front drum to disc brakes? [Re: skicker] #2050260
04/09/16 10:27 AM
04/09/16 10:27 AM
moparx Offline
moparx  Offline
if you have the earlier control arms and the ball joints and bushings are in good shape, dr.diff sells a spacer that adapts the taper of the small balljoint to the bigger taper in the disc spindle. i have used these and they work very well ! just something for some to consider if contemplating changing upper arms.
beer
Re: Need to converting 65 b body front drum to disc brakes? [Re: sixpacksteve] #2050302
04/09/16 11:28 AM
04/09/16 11:28 AM
Andrewh Offline
Andrewh  Offline
moparx is talking about a-bodies. just so you are not confused. the 65 b doesn't need anything but the spindles. you don't need the upper or lower anything to bolt it up.
Re: Need to converting 65 b body front drum to disc brakes? [Re: Andrewh] #2050316
04/09/16 11:42 AM
04/09/16 11:42 AM
moparx Offline
moparx  Offline
that is correct sir. just somehow got A bodies in the head.
beer
