1988 dodge 3/4 ton steering column question #2046784
04/05/16 12:51 AM
04/05/16 12:51 AM
Indiana
Q
qgrayless Offline OP
Q
Indiana
Ok folks I am a newbie. My question is I have a 1988 dodge 2500 3/4 ton it has the automatic steering column no tilt the problem I have is I can not find parts for it so my question is can I put a tilt steering column in it and what year would interchange. Thanks for your help.
Re: 1988 dodge 3/4 ton steering column question [Re: qgrayless] #2046994
04/05/16 12:01 PM
04/05/16 12:01 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
I would say you would be safe '81-'93, maybe even older, the only thing to check would be the wire plugs for match up.
1981 Dodge D150 360 auto
Re: 1988 dodge 3/4 ton steering column question [Re: qgrayless] #2047020
04/05/16 12:40 PM
04/05/16 12:40 PM
Northern MN
1E2C Offline
1E2C  Offline
Northern MN
If it's a manual, no tilt column - the clutch pedal will interfere with the ignition switch. Otherwise no issues as long as your wiring matches although if you get into cruise and other options that wiring can limit you pretty hard.
Re: 1988 dodge 3/4 ton steering column question [Re: basketcase] #2047125
04/05/16 02:36 PM
04/05/16 02:36 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
You will find that the steering gear box and column are common to GMC & Chevrolet trucks of similar vintage, so don't limit your boneyard scrounging to just the Dodge nameplates. Just be sure to get a manual column if you have a manual box and a P/S column is you have P/S because they are different lengths.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: 1988 dodge 3/4 ton steering column question [Re: qgrayless] #2047154
04/05/16 03:15 PM
04/05/16 03:15 PM
Northern MN
1E2C Offline
1E2C  Offline
Northern MN
Pete's got that right - if you're not insisting on plug-n-play there's a whole lotta stuff can be made to work fairly easily. I once used a 72 D100 column in a 66 C10, all bolted in fine it just took me a couple hours to get the turn signals wired right.
Re: 1988 dodge 3/4 ton steering column question [Re: qgrayless] #2047307
04/05/16 07:15 PM
04/05/16 07:15 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
What parts are you after?
Straight swap columns are 87-90 pickup and ramcharger. Tilt column from the same also bolt in just hbe sure to get the adaptor harness with the column.
Note the tilt column used in these trucks was built by Saginaw, like year GM parts fit to repair them.
Angry white pureblood male
Re: 1988 dodge 3/4 ton steering column question [Re: qgrayless] #2048333
04/06/16 09:37 PM
04/06/16 09:37 PM
Indiana
Q
Q
Indiana
I need the complete turnsignal unit. every place that I have looked up says they are discontinued and all they have is the one for tilt steering. So with me being a little fat man I thought I would see about the tilt steering option. Thanks to all who replied
Re: 1988 dodge 3/4 ton steering column question [Re: qgrayless] #2049259
04/07/16 10:12 PM
04/07/16 10:12 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Sounds like you will be junkyarding it. Ramcharger have tilt more often than pickups
Note 2wd and 4wd use different intermediate shafts so keep yours till the swap is done. Or get a column from a similar equipped truck.
Could also call the dealer for a factory pn then check fleabay for a listing.
Re: 1988 dodge 3/4 ton steering column question [Re: qgrayless] #2049276
04/07/16 10:32 PM
04/07/16 10:32 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
sadly the gm columns automatic shift actuates the shift rod on the wrong side of the column---which takes some engineering to get the shift points right---stay dodge....
