Page 3 of 5 1 2 3 4 5
Re: Welding for a novice/newbie [Re: justinp61] #2046269
04/04/16 02:27 PM
04/04/16 02:27 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
Originally Posted By justinp61
Originally Posted By Stanton
I just got another small roll of flux core wire and will use it with the c25 gas. This process is called dual shield welding and produces near perfect welds for newbies.
This is hilarious but April Fools was Friday! This is like wearing suspenders AND a belt - totally unnecessary. Learn to weld with either/or but both is a crutch you'll never get rid of.
And to the point of producing "near perfect" welds, lets focus on that. First the word "near" - so they're still not "perfect" so why bother! Second, the shielding plays such a small role in the whole scheme of things that using two shielding methods is ridiculous. Torch angle, stickout, voltage/amperage settings and speed of travel play a much larger role in the quality of the weld. Shielding ... you set the gas flow and forget it!
Seriously, you don't take advice from a "beginner" on how to weld !!
Actually shielded gas flux core mig is a very good process in applications that require a lot of penetration. It's also very good for vertical up. It's not needed for sheet metal or light fab work.
I had never seen it used before and I am not a newbie as Stanton seems to think. I started playing with welders in high school metal shop and used a huge DC arc welder to box and Z a Model A frame. I developed some bad habits over the years and found the refresher course helpful. I don't weld every day as some of you do, but I have the equipment to do so. Still playing with cars and will be 70 in August. Just another Old Fart.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Welding for a novice/newbie [Re: roe] #2046287
04/04/16 02:48 PM
04/04/16 02:48 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
The welding class is a good idea. Most welding shops will give you student discounts. The class will also go over all the safety stuff you should know about. Stuff like phosgene gas, or welding a container that had flammable material in it (un purged) can kill you.
A class will also develop your skills faster, and show you how to inspect and test your welds.
As mentioned, one issue mostly seen in mig welding (compared to other weld processes), is a nice looking weld that has no penetration.
Besides the welder, you will need a helmet, gloves, and a 4" grinder with a wire wheel at minimum. For grinding I like to use 60-grit flap wheels and the thin cutoff wheels. Others like the standard grinding wheels.
Re: Welding for a novice/newbie [Re: roe] #2046289
04/04/16 02:50 PM
04/04/16 02:50 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I have a Lincoln Handy Mig.
http://www.lincolnelectric.com/en-ca/equipment/Pages/product.aspx?product=K2185-1(LincolnElectric)
I bought it years ago for $250 off ebay (new in box). I bought it because at the time I only had access to 110v. It does MIG and flux core wire. Comes with a basic regulator for the argon/co2 gas and welds up to 1/8" steel. Wire feed speed is an infinitely adjustable dial, heat is a 4 position switch. I have found it capable to do all repairs on these old cars. It's more than enough to do sheet metal repairs, floor pans, frame connectors and frame patching. Not much on these old cars is even 1/8" thick unless you're talking about welding diff parts or motor mounts. I've put a decent amount of use on it and it's done me well. I would like to upgrade to a bigger machine so I could weld heavier steel, but the reality is that it's very rare I have a need for that. I would definitely buy this machine again. FWIW I did use my buddy's fancy Miller at his body shop a bit to do some panel patching, and for that kind of work, I didn't really find his did any better of a job than mine.
Re: Welding for a novice/newbie [Re: roe] #2046413
04/04/16 05:27 PM
04/04/16 05:27 PM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
But when it comes to welding thicker stuff, will yours do as good of a job as his ???? Nobody is denying the ability of a 110v welder to do sheet metal, they just lack the balls to do heavy stuff which limits their versatility. But as is typical of this site, someone's going to say they've welded 1/2" plate with one !!
Re: Welding for a novice/newbie [Re: Stanton] #2046416
04/04/16 05:34 PM
04/04/16 05:34 PM
Manitoba, Canada
Manitoba, Canada
Absolutely! However how much 1/2" thick stuff is there on these old cars? Hint: not much. How much steel is thicker than 1/8" on these old cars? Hint: not much. The little 110v Lincoln can handle 95% of the jobs there is to do on these old cars. I said I would like to upgrade to a bigger machine, so I can tackle that last 5%.
Re: Welding for a novice/newbie [Re: roe] #2046459
04/04/16 06:30 PM
04/04/16 06:30 PM
Niwot, CO Formerly denn...
dynorad Offline
dynorad  Offline
I own a welding supply business. 140A is OK for sheetmetal, anything much bigger will not penetrate and you will get something that looks like a weld but is not.
180A is a nice size. We sell both Lincoln and Miller, they are both fine. A new option is Forney. The Forney uses standard Tweco consumables and has the heavy duty wire drive like the industrial grade Lincoln machines.
I personally would not buy a Harbor Freight. If it needs repair you are SOL.
Re: Welding for a novice/newbie [Re: roe] #2046518
04/04/16 07:21 PM
04/04/16 07:21 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Dang Dennis, I didn't know that is what your doing now.
I just bought a 330 cf bottle of Argon from Matherson.
I do need Oxygen and Acetylene bottles for my Smith 40 series.
It has the regulator for CGA510 tank valve.
I still have the old Dynorad, but it's in the garage.
Re: Welding for a novice/newbie [Re: roe] #2046577
04/04/16 08:30 PM
04/04/16 08:30 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I've been using the little Lincoln 3200 HD (stolen) and Weld Pack 140 for 10+ years. They are little 110 VAC machines and will do anything in steel that a typical home gamer needs.
I haven't found them to be lacking yet.
http://www.homedepot.com/p/Lincoln-Electric-Weld-Pak-140-HD-Wire-Feed-Welder-K2514-1/100670934
- Stu Harmon
Re: Welding for a novice/newbie [Re: 1971 Gran Coupe] #2046774
04/05/16 12:41 AM
04/05/16 12:41 AM
Central TX
roe Offline OP
roe  Offline OP
Central TX
First of all thanks to everyone for taking the time to add to the discussion and share your opinions. After taking it all in I'm going with a combination of a few people's advice. I'm going to go with something new for the warranty and with consumables that are easily found. I'm also going to stay within my budget and get something that should handle everything I need to tackle no problem. It's a mig machine so I can do flux core, mig, or the dual shield. I'm going to pick up the Eastwood recommended below by 1971GranCoupe. I'm also going to look into a welding class and if no luck there I'll see if I can get a local welder to give me some tips/guidance.
http://www.eastwood.com/mig-welder-110vac-135a-output.html
roe
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: Welding for a novice/newbie [Re: roe] #2046780
04/05/16 12:46 AM
04/05/16 12:46 AM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
^ spend the money you saved on a nice mask, i bought a cheaper auto darkening. then i got a nice jackson with a millermatic210 i bought. difference was huge.
get alot of contact tips and work on figuring out how the machine works, consistent wire feed, keeping tips and nozzle clean...have fun.
Re: Welding for a novice/newbie [Re: krautrock] #2046783
04/05/16 12:50 AM
04/05/16 12:50 AM
Central TX
roe Offline OP
roe  Offline OP
Central TX
Will do. I hear the auto darkening hoods from harbor freight are pretty good. But here is where I will get something that I have full confidence in and not sweat it. I like my eyesight panic
Edit: Lso need some welding gloves and maybe a welding blanket
Re: Welding for a novice/newbie [Re: roe] #2046873
04/05/16 03:43 AM
04/05/16 03:43 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Do the welding class before buying a machine. You may find some leads on good used equipment at the school, and what you lean will add more info for making a decision.
A good auto-darken helmet is a great investment. Again, get a brand name one where you can get replacement lenses for it.
Re: Welding for a novice/newbie [Re: dynorad] #2046962
04/05/16 11:18 AM
04/05/16 11:18 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I guess there is a big difference between owning a business and being familiar with the product.
I have welded 3/8 plate with my little 110 machine then beat the crap out of the piece. I ended up tearing the plate but never broke the weld.
It was good enough for me to put together a goose neck trailer hitch plate for the bed of my truck. That hauled 18,000 lbs of steel from OKC to DFW.
Tell me again how bad a 110 VAC machine is.
I no doubt maxed my machine but with careful prep and proper use you can do quite a bit of work with them.
- Stu Harmon
Re: Welding for a novice/newbie [Re: roe] #2046964
04/05/16 11:22 AM
04/05/16 11:22 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I ran one of those for years. When it died in the middle of a job at work I ran to Lowes and picked up one of their auto darkening hoods. It was MUCH nicer than the HF piece of junk.
Again, a bit more money but not that much. It made a significant difference.
- Stu Harmon
Re: Welding for a novice/newbie [Re: feets] #2046977
04/05/16 11:41 AM
04/05/16 11:41 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I have welded 3/8 plate with my little 110 machine and beat the crap out of it. I ended up tearing the plate but never broke the weld.
Well the Space Shuttle did pretty well on on the first 24 launches, but the that number 25 was a bummer. Big difference between what can be done and what should be done. twocents
Re: Welding for a novice/newbie [Re: roe] #2046990
04/05/16 11:56 AM
04/05/16 11:56 AM
Ontario, Canada
Don't question me!
Don't question me!
Ontario, Canada
So OP, are ya sorry ya posted here? Like everything else, it turns into a pissing match and you end up wondering "[ Moparts Family Site - Keep it Friendly ] did I just start". And since amateurs outnumber the pros, you're exposed to all the bad practices that these guys got lucky with as opposed to the safe practices the pros know will stand the test of time.
Re: Welding for a novice/newbie [Re: Stanton] #2046999
04/05/16 12:15 PM
04/05/16 12:15 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
If you use a machine within it's rated capacity and do so properly you will be fine.
If you try to use a machine outside it's rated capacity you will not have a good result.
- Stu Harmon
Re: Welding for a novice/newbie [Re: roe] #2047171
04/05/16 03:31 PM
04/05/16 03:31 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
A small welder has the power for sheet metal, and if your just hanging sheet metal and the weld cracks, you may get a crack in the paint. If your welding a rollbar or suspension that's another story.
https://www.youtube.com/watch?v=cMoXOky6buA
https://www.youtube.com/watch?v=1nVrr_XTin4
Re: Welding for a novice/newbie [Re: 451Mopar] #2047173
04/05/16 03:35 PM
04/05/16 03:35 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I've seen bad welds made with top notch equipment.
If you use the machine properly and within it's designed limits you should be fine.
Use ANY machine improperly and you will have problems.
Use ANY machine outside it's designated limits and you will have problems.
- Stu Harmon
Re: Welding for a novice/newbie [Re: feets] #2047181
04/05/16 03:44 PM
04/05/16 03:44 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I agree, you have to learn proper prep and welding technique (and saftey) that is why the class is recommended.
