U joint question
#204533
01/25/09 10:41 PM
01/25/09 10:41 PM
Posts: 5,618 long island NY
Ari440
long island NY
I have a 72 road runner 440 ,727 trannie and a 8 3/4 rear the driveshaft I have is the small u joint in the front but the pinoin on the 8 3/4 uses the large u joint in the back they make a universal u joints ,big on one side small on the other do you know where I can find one any part number you can give me thanks
1.39 9.85 - 137 mph
Re: U joint question
[Re: pushbutton]
#204537
01/25/09 11:06 PM
01/25/09 11:06 PM
Ari440
long island NY
I did get two napa u joints ,dont have part numbers in front of me
for some reason they only had C clips on one side on the joints
I will see if I could mix the two sets up to make it work
just woundering if I am missing something
C clips on the driveshaft side but not on the pinoin side and the cups whould not hold ,and fall out
1.39 9.85 - 137 mph
[Re: Ari440]
#204538
01/25/09 11:13 PM
01/25/09 11:13 PM
Posts: 1,565 tennessee
pushbutton
tennessee
Might have been for a Ford yoke. Ijust went out to the garage and looked at one i have. Spicer#5-527x same as the Mancini number. I think i got it at NAPA.
[Re: Ari440]
#204540
01/25/09 11:15 PM
01/25/09 11:15 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Ari, car looks nice!!
any pics with the motor installed?
[Re: Ari440]
#204546
01/25/09 11:29 PM
01/25/09 11:29 PM
Ari440
long island NY
1.39 9.85 - 137 mph
[Re: Ari440]
#204547
01/25/09 11:33 PM
01/25/09 11:33 PM
pushbutton
tennessee
ford yoke has tabs on the side , to hold the cups in , on the pinion ?
I bought a used chunk one time that had a yoke that had tabs on it to hold the caps on,somebody told it was prob a Ford. I know the Mopar joint I had wouldn't work. Had to change it out. I don't know for sure that it was Ford.
[Re: Ari440]
#204549
01/25/09 11:35 PM
01/25/09 11:35 PM
fast68plymouth
So. Burlington, Vt.
thanks for the pics. thats a pretty nice car i'm sure you'll enjoy tearing up the streets in that thing all summer long
[Re: Ari440]
#204551
01/26/09 09:47 AM
01/26/09 09:47 AM
pushbutton
tennessee
thank you PUSHBUTTEN and 5537SG
I will look up the part numbers
Your welcome,thats a nice looking ride.
[Re: Ari440]
#204552
01/26/09 11:17 AM
01/26/09 11:17 AM
Posts: 189 long island new york
kingdust
Ari I have one of those joints. I also have the larger style yoke and you can put the 7290 joint in the shaft. Call me 516 3817622. Later mark!
LIFE IS A LESSON,YOU LEARN IT WHEN YOUR THROUGH!
