Re: cylinder head removal in car, e-body, w/headers ???
[Re: cocamcuda]
#2041661
03/30/16 01:47 AM
03/30/16 01:47 AM
RapidRobert
No Cuda exp but I would try & see how far it appears the headers need to move sideways to access the outer bolts & see if looks like the headers have room to move out that distance. Definitely grab some blankets which is gonna decrease that distance. in the middle of it if it appears a no go then disciple yourself to go back together then on to plan B
[Re: cocamcuda]
#2041696
03/30/16 02:56 AM
03/30/16 02:56 AM
Posts: 4,848 Memphis
HemiRick
Memphis
If you unbolt the engine mounts and lift the engine some, the headers should come out no problem....this is less work, than dropping the whole subframe.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
