71 cuda will not start with key #2040982
03/29/16 05:06 AM
03/29/16 05:06 AM
ME
79machocharger Offline OP
ME
So my 71 cuda just started having issues with trying to start it. If I try starting it cold with the key it does nothing, not even a click. I however can start it by jumping the starter relay with the key in the start position. Once it's running I can shut the car off and can now start it with the key. Any ideas on what may be causing this issue?
Re: 71 cuda will not start with key [Re: 79machocharger] #2041091
03/29/16 11:55 AM
03/29/16 11:55 AM
there is a part time poor continuity/connection somewhere between the "ST" terminal on the ign switch (& possibly the sw itself but way less likely) and the "ign" terminal on the starter relay that the yellow with tracer wire goes to. Could also be an intermittent ground in the NSS circuit from the "grn" terminal on the starter relay to the auto trans or clutch whichever you have. I would seperate the bulkhead and the dangling connector under the steering column & give the metal terminals a quick cleaning but if you have a VOM and a helper I would have him hold the key to start & you under the hood see if you have fire at the bulkhead wire that goes to the starter relay then either work forwards or backwards (from there) to pin down quicker which one has the open
Re: 71 cuda will not start with key [Re: 79machocharger] #2041143
03/29/16 01:06 PM
03/29/16 01:06 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
I had that problem once..cleaned and wire brushed the terminals on the relay..
Re: 71 cuda will not start with key [Re: 79machocharger] #2041203
03/29/16 02:52 PM
03/29/16 02:52 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Clean the terminals and the connections at the relay.By the way thats not a no start.its a no crank.Drove me nuts at the shop when people came in and said my car wont start and it was a no crank.Big difference.Rocky
Chrysler Firepower
