Re: 71 cuda will not start with key
[Re: 79machocharger]
#2041091
03/29/16 11:55 AM
03/29/16 11:55 AM
RapidRobert
there is a part time poor continuity/connection somewhere between the "ST" terminal on the ign switch (& possibly the sw itself but way less likely) and the "ign" terminal on the starter relay that the yellow with tracer wire goes to. Could also be an intermittent ground in the NSS circuit from the "grn" terminal on the starter relay to the auto trans or clutch whichever you have. I would seperate the bulkhead and the dangling connector under the steering column & give the metal terminals a quick cleaning but if you have a VOM and a helper I would have him hold the key to start & you under the hood see if you have fire at the bulkhead wire that goes to the starter relay then either work forwards or backwards (from there) to pin down quicker which one has the open
#2041203
03/29/16 02:52 PM
03/29/16 02:52 PM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
Clean the terminals and the connections at the relay.By the way thats not a no start.its a no crank.Drove me nuts at the shop when people came in and said my car wont start and it was a no crank.Big difference.Rocky
Chrysler Firepower
