can I use 5w/30 in an spec 5w/20 engine #2040481
03/28/16 03:46 PM
03/28/16 03:46 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
I have a case of really good syntho 5w/30 oil. My 03 Crown Vic is ready for an oil change, it calls for 5w/20 can I use 5w/30 w/o any issues?
Re: can I use 5w/30 in an spec 5w/20 engine [Re: Mr.Yuck] #2040497
03/28/16 04:09 PM
03/28/16 04:09 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i don't see why not.
Re: can I use 5w/30 in an spec 5w/20 engine [Re: lewtot184] #2040502
03/28/16 04:14 PM
03/28/16 04:14 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
You'd think that but my buddy used 5w/30 in his 07 Magnum (5.7 hemi) and it started flashing codes on him.
Re: can I use 5w/30 in an spec 5w/20 engine [Re: Mr.Yuck] #2040504
03/28/16 04:16 PM
03/28/16 04:16 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Check the owners manual. Usually they say it is OK in warmer weather.
Re: can I use 5w/30 in an spec 5w/20 engine [Re: 451Mopar] #2040509
03/28/16 04:29 PM
03/28/16 04:29 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
I don't have one.... I'll "Google it".
Re: can I use 5w/30 in an spec 5w/20 engine [Re: Mr.Yuck] #2040531
03/28/16 04:54 PM
03/28/16 04:54 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I used to run that in a 4.6.
I want my fair share
Re: can I use 5w/30 in an spec 5w/20 engine [Re: Mr.Yuck] #2040575
03/28/16 06:19 PM
03/28/16 06:19 PM
Central NC
gch Offline
gch  Offline
Central NC
The MDS system specs 5w20 in the hemi vehicles.In a Ford 4.6 (especially with some miles) it wouldn't bother me a bit.
Re: can I use 5w/30 in an spec 5w/20 engine [Re: Mr.Yuck] #2040607
03/28/16 07:35 PM
03/28/16 07:35 PM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
You can run 15w40 if yah want. But the drainbacks in those Fords are so horrifying it might take a while to get back in the pan.
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: can I use 5w/30 in an spec 5w/20 engine [Re: 451Mopar] #2040610
03/28/16 07:46 PM
03/28/16 07:46 PM
Kirkland, Washington
Pacnorthcuda Offline
I don't doubt that some owner's manuals state that, but its kind odd reasoning. The weather has much more effect on lubrication during cold engine startup--when the 5w viscosity comes into play.
Engines operating temps are largely controlled by the thermostat, not the weather--when the 20w or 30w is in effect.
It would make more sense to state that a 10w/20 (if one existed)can be run in warm climate than a 5w/20
Re: can I use 5w/30 in an spec 5w/20 engine [Re: Mr.Yuck] #2040695
03/28/16 09:28 PM
03/28/16 09:28 PM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
I run Mobil 1 10W 30 in my 08 Bullitt mustang. rec oil is 5W 20.
motor is built but I still use the variable cam timing.
perception is 90% of reality
Re: can I use 5w/30 in an spec 5w/20 engine [Re: Mr.Yuck] #2040729
03/28/16 10:09 PM
03/28/16 10:09 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
5.7 in a Magnum has MDS which requires 5w20 to function correctly.
Your Crown Vic doesn't have that stuff so you'll be good.
I ran 10w30 in my Towncar because with 5w20 the cam chain tensioners would bleed off overnight and it sounded like a thrashing machine until it pressured up.
Kevin
Re: can I use 5w/30 in an spec 5w/20 engine [Re: Mr.Yuck] #2041019
03/29/16 10:03 AM
03/29/16 10:03 AM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
Thanks people.
Re: can I use 5w/30 in an spec 5w/20 engine [Re: Mr.Yuck] #2041064
03/29/16 11:00 AM
03/29/16 11:00 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
My Wrangler called for 5w-20, I used 5w-30 in it for 80,000 miles and no issues.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
