Re: can I use 5w/30 in an spec 5w/20 engine
[Re: Mr.Yuck]
#2040497
03/28/16 04:09 PM
03/28/16 04:09 PM
Posts: 3,916 usa
lewtot184
usa
[Re: 451Mopar]
#2040509
03/28/16 04:29 PM
03/28/16 04:29 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Check the owners manual. Usually they say it is OK in warmer weather. I don't have one.... I'll "Google it".
[Re: Mr.Yuck]
#2040607
03/28/16 07:35 PM
03/28/16 07:35 PM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
You can run 15w40 if yah want. But the drainbacks in those Fords are so horrifying it might take a while to get back in the pan.
When it takes more than a sweet mullet to prove you rule at the trailer park..
[Re: 451Mopar]
#2040610
03/28/16 07:46 PM
03/28/16 07:46 PM
Posts: 21,831 Kirkland, Washington
Pacnorthcuda
Check the owners manual. Usually they say it is OK in warmer weather. I don't doubt that some owner's manuals state that, but its kind odd reasoning. The weather has much more effect on lubrication during cold engine startup--when the 5w viscosity comes into play. Engines operating temps are largely controlled by the thermostat, not the weather--when the 20w or 30w is in effect. It would make more sense to state that a 10w/20 (if one existed)can be run in warm climate than a 5w/20
[Re: Mr.Yuck]
#2040695
03/28/16 09:28 PM
03/28/16 09:28 PM
Posts: 4,923 new berlin wisconsin
Mr T2U
I run Mobil 1 10W 30 in my 08 Bullitt mustang. rec oil is 5W 20.
motor is built but I still use the variable cam timing.
perception is 90% of reality
