e 3 plugs in my 360 #2039928
03/27/16 07:00 PM
03/27/16 07:00 PM
Streetsboro,Ohio
70dart318 Offline OP
Streetsboro,Ohio
I put E 3 spark plugs in my fresh built 360. Ran it about 350 miles and checked the plugs and they were black. It ran ok but not the way I thought it should have. Has anyone used these plugs? I removed them and put NGK plugs in. It seems to run much better. I'm going to put another 350 or so miles on them and check these plugs. We set the timing and ajusted the carb. twice with the old plugs I hope this helps.
Re: e 3 plugs in my 360 [Re: 70dart318] #2039932
03/27/16 07:02 PM
03/27/16 07:02 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Seems to me three electrodes would shield the spark rather than make it better. shruggy
Re: e 3 plugs in my 360 [Re: 70dart318] #2039965
03/27/16 08:09 PM
03/27/16 08:09 PM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
Personally I think E3's are just snake oil that burn too hot. E3 have there heat ranges all pooched imo. Unless you have coil packs wouldn't waste my time with iridium or platinum plugs either. Stick with your favorite single ground regular plug & check and replace every couple years.
My pos E3's:
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: e 3 plugs in my 360 [Re: 70dart318] #2039976
03/27/16 08:40 PM
03/27/16 08:40 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
If it worked as advertised all the OEM's would be running them.
They don't.
Don't be the exception.
Re: e 3 plugs in my 360 [Re: 70dart318] #2039988
03/27/16 08:55 PM
03/27/16 08:55 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Tony
70 AARCuda Vitamin C
Re: e 3 plugs in my 360 [Re: 70AARcuda] #2039997
03/27/16 09:08 PM
03/27/16 09:08 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Originally Posted By 70AARcuda
LOL! Force will tell you anything is great as long as they pay him money. laugh2
Re: e 3 plugs in my 360 [Re: Supercuda] #2040325
03/28/16 10:52 AM
03/28/16 10:52 AM
moparx Offline
moparx  Offline
They don't.
right there is your answer. i never thought much good about them and their claims......, but hey, the "tornado" [remember that "fine" item?] made more horsepower and you got LOTS better gas mileage as well, and it was cheaper to boot than a set of e3 plugs. but wait ! if you order in the next ten minutes, you will receive 2 "tornadoes" for the price of one ! laugh2
beer
Re: e 3 plugs in my 360 [Re: 70dart318] #2040475
03/28/16 03:38 PM
03/28/16 03:38 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Suppose you had:
one or two single cylinder gasoline engine generators
One or two of those Kill-O-Watt electric power meters that display killowatts and kw-hrs,
One or two electric resistance heaters of 1500 watts to load the generator,
How would you use these "semi-dynos"
To test one spark plugs claims against another?
(just seeking out ideas)
Re: e 3 plugs in my 360 [Re: 70dart318] #2040594
03/28/16 07:13 PM
03/28/16 07:13 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Can you precisely measure fuel flow?
You have to be able to account for all the variables, including the weather, to be accurate.
Not real easy with a home brew setup.
I guess with identical loads you could run a precisely measured amount of fuel thru and time how long it takes to consume the fuel with each type plug as a sort of estimate of effectiveness.
Ever notice all the car shows that run E3 replace wore out plugs with new E3's and claim they make a difference, yep, same difference any NEW set of
plugs would make.
Of course the difference is mitigated by ZMax
lol.
crap in a can.
Re: e 3 plugs in my 360 [Re: 70dart318] #2040604
03/28/16 07:33 PM
03/28/16 07:33 PM
Its a TRAP!
DARTH V8Я Offline
DARTH V8Я  Offline
Its a TRAP!
My pic above was after 2600k. Then the misfires & cold start problems happened. Save my old AC delcos (ya ya) with 70k from before, put those back in and everything was as right as rain. As far as fuel economy, I didn't notice a difference because I was putting in the same amount every week with similar mileage (more or less). Horsepower/acceleration didn't notice a difference right up to that 2600k mark. The pic above explains the rest.
