Re: e 3 plugs in my 360
[Re: 70dart318]
#2039965
03/27/16 08:09 PM
03/27/16 08:09 PM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
Personally I think E3's are just snake oil that burn too hot. E3 have there heat ranges all pooched imo. Unless you have coil packs wouldn't waste my time with iridium or platinum plugs either. Stick with your favorite single ground regular plug & check and replace every couple years. My pos E3's:
When it takes more than a sweet mullet to prove you rule at the trailer park..
[Re: 70dart318]
#2039976
03/27/16 08:40 PM
03/27/16 08:40 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
If it worked as advertised all the OEM's would be running them.
They don't.
[Re: 70dart318]
#2040594
03/28/16 07:13 PM
03/28/16 07:13 PM
Supercuda
About to go away
About to go away
up yours
Can you precisely measure fuel flow?
You have to be able to account for all the variables, including the weather, to be accurate.
Not real easy with a home brew setup.
I guess with identical loads you could run a precisely measured amount of fuel thru and time how long it takes to consume the fuel with each type plug as a sort of estimate of effectiveness.
Ever notice all the car shows that run E3 replace wore out plugs with new E3's and claim they make a difference, yep, same difference any NEW set of plugs would make.
Of course the difference is mitigated by ZMax
lol.
crap in a can.
[Re: 70dart318]
#2040604
03/28/16 07:33 PM
03/28/16 07:33 PM
DARTH V8Я
Its a TRAP!
My pic above was after 2600k. Then the misfires & cold start problems happened. Save my old AC delcos (ya ya) with 70k from before, put those back in and everything was as right as rain. As far as fuel economy, I didn't notice a difference because I was putting in the same amount every week with similar mileage (more or less). Horsepower/acceleration didn't notice a difference right up to that 2600k mark. The pic above explains the rest.
