Re: can you fit a single plane intake under a 71 power bulge?
[Re: Adam71Charger]
#2039986
03/27/16 08:49 PM
03/27/16 08:49 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
The power bulge hood does give a good amount of clearance. My 451 Engine, 400 block, B1-b/s heads, Mopar M1 with 1" spacer and 1,000 cfm 4150 HP holley carb, along with a Moroso drop base air filter, 3" filter element and K&N filter top all fit under the bulge hood.
Same for the current 500" 400 stroker with Victor MW heads, Indy single plane, and Quick Fuel 4150 E-85 carb with the same air filter setup as above.
There are also filter bases with more drop, just need to make sure the top lid clears the top of the carb by at least an inch.
