How much clearance between oil pan and drag link? #2036249
03/22/16 03:44 AM
03/22/16 03:44 AM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
I am trying to get my car all hacked up and reinforced for the G Force GF5R transmission and was hoping you all could help out with locating the engine/trans and crossmember.
Unfortunately I didn't see the G Force swap coming so we didn't measure anything prior to removing the transmission. Adding to that is that the rear spring are junk. The rear segment of the longest leaf is bent on both sides so measuring anything off of the diff is of no use.
Getting into the details, the car sits 2.5* nose down measured off of the inner fender well ('66 B-body). I was assssssuming that the carb flange should be level (0*) however there no clearance between the hemi style oil pan and draglink/centerlink or whatever you want to call it.
I'd like to think that if the carb pad was level the crank centerline would be 3* down but I have not got that far.
I'm not really sure where to start here other than I know the following:
1) The transmission should be angled down.
2) Drag link to oil pan clearance must exist - how much?
3) The headers must have clearance for both the floor pan and torsion bars.
Any thoughts? How much clearance do you guys have between you draglink/centerlink and the oil pan? I can see where our setup was VERY close but not rubbing.
Hopefully I'll have the engine in a week or so and then I can install it and the headers to see where we are at in real time. In the mean time take me to school!
Re: How much clearance between oil pan and drag link? [Re: Jeremiah] #2036255
03/22/16 04:16 AM
03/22/16 04:16 AM
I would wait until the motor is in the car with the heads and headers and then measure and worry about the oil pan to steering center link. I had about 1/2 inch on my old Duster with the wheels straight ahead, the center link would hit the passenger side of the oil pan when turned to the max for right turns shruggy It didn't turn as far to the right at it did to the left whiney shruggy
Changing the subject, I hope to have my 1966 Coronet Deluxe in my shop in the next two weeks to start on swapping the 6 cylinder K member out and installing the new front suspension parts and disc brakes along with the 440 motor and the NP 833 O.D. tranny behind it luck I may be able to help you more on the stock angles and clearances then thumbs
Re: How much clearance between oil pan and drag link? [Re: Cab_Burge] #2036381
03/22/16 12:21 PM
03/22/16 12:21 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Thanks Cab! Much appreciated. I am for sure going to install the engine in the car with the headers prior to breaking out the welder.
Re: How much clearance between oil pan and drag link? [Re: Jeremiah] #2036413
03/22/16 01:02 PM
03/22/16 01:02 PM
Minn
SportF Offline
SportF  Offline
Minn
If this is the same center link as a 63 B body, the link fits on two ways. There is about .75 inches in clearance between the two. It looks like it won't make a difference, but it does. And it would seem the "right way" the link looks, is actually the wrong way.
As I recall, the link, shaped like a "U", the bottom of the "U" goes to the front.
I checked a bunch of cars at the track last summer, and everyone, including my race car, was on backwards. Handling and geometry are the same either way, but it makes a clearance difference.
Re: How much clearance between oil pan and drag link? [Re: Jeremiah] #2036569
03/22/16 04:54 PM
03/22/16 04:54 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Cars with conventional rubber motor mount biscuits need more safety clearance than with polyurethane biscuits, which need more than engines with motor plates.
If you smack the link hard enough to do anything, your toe and bump steer will go out.
Boffin Emeritus
Re: How much clearance between oil pan and drag link? [Re: polyspheric] #2038209
03/25/16 01:30 AM
03/25/16 01:30 AM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Any others want to weigh in on this topic? Man, this place has really dropped off! C'mon back!
Re: How much clearance between oil pan and drag link? [Re: Jeremiah] #2038217
03/25/16 01:37 AM
03/25/16 01:37 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Why not, elephant ears, rubber trans mount and I have very little clearance between the link and pan maybe 1/4" and it hits the pan on full turns.............
Re: How much clearance between oil pan and drag link? [Re: Thumperdart] #2038250
03/25/16 02:34 AM
03/25/16 02:34 AM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Thank you Dom, that's what I was after. This car is going to retain the stock mounts for now. The black car has a motor plate so I'll be asking again when it's time comes!
4150 carb, stock style motor mounts, stick shift...nothing to be scared of for the casual onlooker. Well, other than the body style. It's a '66 Charger and that will frighten almost anyone!
Re: How much clearance between oil pan and drag link? [Re: Jeremiah] #2038525
03/25/16 03:04 PM
03/25/16 03:04 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`m frightened just thinking about it...........lol!
Re: How much clearance between oil pan and drag link? [Re: Jeremiah] #2038543
03/25/16 03:23 PM
03/25/16 03:23 PM
michigan
turbo toad Offline
turbo toad  Offline
michigan
This is a low deck in a 62 valiant with a V8 Drop link theres about 1/2 of a inch of clearance. If you need a more accurate measurement let me know and after i got out of work ill take a better measurement
Check out my build on Facebook Ttoad Hurley its updated regularly
Re: How much clearance between oil pan and drag link? [Re: Jeremiah] #2044577
04/02/16 05:38 PM
04/02/16 05:38 PM
Frederick, MD
71charger Offline
71charger  Offline
Frederick, MD
Center link on my Charger was hitting the pan keeping it from being properly aligned. Taking it out and end for ending it gave the needed clearance. I have rubber mounts, a Milodon 5 qt pan, and a CAP k-frame.
Re: How much clearance between oil pan and drag link? [Re: Jeremiah] #2044643
04/02/16 07:18 PM
04/02/16 07:18 PM
Milwaukee, WI
moparjimbo Offline
moparjimbo  Offline
Milwaukee, WI
I had to do this on my 67 Fury - This is with the steering all the way one way - I really wanted that fabbed aluminum pan to fit!
1996 Viper GTS - UGR Twin Turbo 1500RWHP, 9.02 @ 167 on pump gas and DOT tire
1973 Challenger - 572 Indy Hemi 860HP
1975 Trailduster Convertible, 440
1967 Plymouth Fury Police Pursuit 2DR 505 Stroker
2004 Neon SRT4 modded
www.milwaukeemopar.com
Re: How much clearance between oil pan and drag link? [Re: moparjimbo] #2045199
04/03/16 12:04 PM
04/03/16 12:04 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Thanks for the replies. I was looking at our stock 383-4 barrel '66 Coronet and it has about 3/4" between the link and the stock pan. I'll let you all know how it stacks up with the Milodon road race pan in a few weeks...if I remember lol.
Thanks again!
Re: How much clearance between oil pan and drag link? [Re: Jeremiah] #2046123
04/04/16 11:21 AM
04/04/16 11:21 AM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
[url=[URL=http://s45.photobucket.com/user/bubby440/media/20160403_184318_zpstbzhtidf.jpg.html][/url]]pan clearance[/url]
This is an old Proform pan i've been running on my Roadrunner for 25 or so years, there's 3/16 clearance.
72 Plymouth Roadrunner 11.08@123.25
Re: How much clearance between oil pan and drag link? [Re: Roughbird72] #2046172
04/04/16 12:30 PM
04/04/16 12:30 PM
Minn
SportF Offline
SportF  Offline
Minn
It is a little hard to tell from that photo, but I believe if you swapped that link end for end, you'd have more clearance. I know it doesn't seem like it makes a difference, but it does.
Edit I didn't see what 71 Charger said above, but it is an example of the difference in how the link is on there.
Re: How much clearance between oil pan and drag link? [Re: Jeremiah] #2046240
04/04/16 01:54 PM
04/04/16 01:54 PM
Roughbird72 Offline
Roughbird72  Offline
The link in my car has no significant difference from one end to the other. I have had no issues thus far.
Re: How much clearance between oil pan and drag link? [Re: Jeremiah] #2048135
04/06/16 05:34 PM
04/06/16 05:34 PM
Someplace you aren't
SomeCarGuy Online content
SomeCarGuy  Online Content
Be sure youre steering wheel is centered, and for that matter the box being indexed correctly on the pitman. Ive heard some replacment worm shafts dont have a master spline, so you can be off somewhere in the mix.
I had a 31580 milodon hit just before full lock turning right. I hadnt aligned the car since I had it and a stock pan cleared fine. Centering things up like they shouldve been provided the needed clearance.
Torque strap is a must with stock mounts. I think you will be fine after checking these details.
I want my fair share
