Re: 69 440 A body Exh. Manifold spacer ? [Re: RR6BBL1969] #1864666
07/05/15 10:51 PM
07/05/15 10:51 PM
blewbyu Offline
blewbyu  Offline
Originally Posted By RR6BBL1969
What is the web address or phone number of big-block-Dave so I can order one of his A body 440 exhaust spacers? Sounds like his is the best from everyone's posts. Thanks
G.G.
You do understand that you only need this if you have the correct drivers side 440 manifold and want to use the original exhaust system. If you are having an exhaust system made locally you do not need really need it it.
Re: 69 440 A body Exh. Manifold spacer ? [Re: blewbyu] #1864729
07/05/15 11:23 PM
07/05/15 11:23 PM
Kentucky USA
RR6BBL1969 Offline
RR6BBL1969  Offline
Kentucky USA
I am quite aware, thank you.
I just need the contact info for Dave.
Re: 69 440 A body Exh. Manifold spacer ? [Re: RR6BBL1969] #1865183
07/06/15 04:23 PM
07/06/15 04:23 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Were you able to get ahold of him? wave
JB Rhinehart, Realist
A-Body's RULE!
Re: 69 440 A body Exh. Manifold spacer ? [Re: 493RT] #1865443
07/06/15 10:00 PM
07/06/15 10:00 PM
Kentucky USA
RR6BBL1969 Offline
RR6BBL1969  Offline
Kentucky USA
I was busy today but will give him a call tomorrow. Thanks
Re: 69 440 A body Exh. Manifold spacer ? [Re: Rhinodart] #2035618
03/21/16 11:22 AM
03/21/16 11:22 AM
Kentucky USA
RR6BBL1969 Offline
RR6BBL1969  Offline
Kentucky USA
Jim, what do you think? Does this look right/correct?
Re: 69 440 A body Exh. Manifold spacer ? [Re: 493RT] #2035690
03/21/16 01:19 PM
03/21/16 01:19 PM
cheshire, ct
davesmopars Offline
davesmopars  Offline
cheshire, ct
If that is from Dave its correct
Keeper of the 440 M code Cuda registry
mcodecuda@yahoo.com
Re: 69 440 A body Exh. Manifold spacer ? [Re: Tom Swope] #2036018
03/21/16 09:38 PM
03/21/16 09:38 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Originally Posted By Tom Swope
Our design is the two lazer cut flanges that are welded together.
The available cast appearing external coating makes the part appear to be pretty close to the original rare piece. The numbers matching user probably would require an nos cast part but this kit was designed to be an economical option to fill a need not for the points correct application.
We have had good success over the years with these kits with no complaints other than a few on this board so we will continue with this design for our specific market. We are appreciative of those on this board that have supported us in the past with both their business and comments. Being a manufacturer of over 500 Mopar exhaust parts any input regarding our product(s) is very much appreciated.
I have to speak for Tom and his crew. I have the stock exhaust on my GTS 383 big block. The fit was great. Had a little difficulty putting the system on but I figured it out. Great workmanship and a great product. Cudos to Tom and his crew.
Abe Lincoln
Re: 69 440 A body Exh. Manifold spacer ? [Re: 493RT] #2036026
03/21/16 09:47 PM
03/21/16 09:47 PM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
I'll end up using their exhaust but I'm using Daves spacer. Almost certain there are no "nos" pieces, only what came on the cars.
Re: 69 440 A body Exh. Manifold spacer ? [Re: 493RT] #2036110
03/21/16 11:29 PM
03/21/16 11:29 PM
cheshire, ct
davesmopars Offline
davesmopars  Offline
cheshire, ct
Dons Exhaust is made from NOS pipes, His son took over the business. Its looks awesome. Use Dave's spacer.
mcodecuda@yahoo.com
Re: 69 440 A body Exh. Manifold spacer ? [Re: davesmopars] #2036237
03/22/16 03:06 AM
03/22/16 03:06 AM
USA
big-block-dave Offline
USA
mine
I'm the CARETAKER of Weinstats '69 440 'cuda registry and have 104 of the 360 cars to date. 84 fastbacks/20 coupes. Always looking for new(REAL M-code) '69 440 'cudas to add to the registry so drop me a note if any are found or known. This isn't a publicly released registry. Thanks, Dave
Re: 69 440 A body Exh. Manifold spacer ? [Re: big-block-dave] #2036238
03/22/16 03:09 AM
03/22/16 03:09 AM
USA
USA
nudder
Re: 69 440 A body Exh. Manifold spacer ? [Re: davesmopars] #2036357
03/22/16 11:51 AM
03/22/16 11:51 AM
Kentucky USA
RR6BBL1969 Offline
RR6BBL1969  Offline
Kentucky USA
The measurements are precise and fit the 440 ex. manifold perfectly. No it's not Dave's , I was given the measurements from an original one. I had several made.
Re: 69 440 A body Exh. Manifold spacer ? [Re: RR6BBL1969] #2036595
03/22/16 05:18 PM
03/22/16 05:18 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Looks good to me! up
A-Body's RULE!
