Cutting housing ends, what to use? #203569
01/25/09 12:08 AM
01/25/09 12:08 AM
Northeast, Alpine, NY
9
9 Sec Phill Offline OP
On a road near you
On a road near you
9
Just wondering what you guys use to cut the axel tubes on rears you need to shorten up. Thanks in advance...Phill
Re: Cutting housing ends, what to use? [Re: 9 Sec Phill] #203570
01/25/09 12:11 AM
01/25/09 12:11 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I've seen them cut with a chop saw, sawzall, or power hack saw.
Re: Cutting housing ends, what to use? [Re: slantzilla] #203571
01/25/09 12:15 AM
01/25/09 12:15 AM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
I bought a cheapo pipe cutter on ebay, I use to cut a straight line in it.
Then I use a cuttoff wheel in a grinder
Re: Cutting housing ends, what to use? [Re: slantzilla] #203572
01/25/09 12:16 AM
01/25/09 12:16 AM
Amarillo, Texas
BBR Offline
BBR  Offline
Amarillo, Texas
I've also heard of guys using a large pipe cutter.
HFT --> No. 3 Pipe Cutter
Drag Week 2011 - 77th place - DD
Drag Week 2012 - 2nd place SRBB N/A
Drag Week 2014 - Kapooya
RMRW 2018
RMRW 2020
Re: Cutting housing ends, what to use? [Re: BBR] #203573
01/25/09 12:29 AM
01/25/09 12:29 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I used a pipe cutter, it cuts clean and straight.
Re: Cutting housing ends, what to use? [Re: 9 Sec Phill] #203574
01/25/09 12:33 AM
01/25/09 12:33 AM
So. IL. USA
PLUM BAD Offline
PLUM BAD  Offline
So. IL. USA
I used a chop saw on my last one. I have also used a sawzaw(SP) and a large hose clamp to mark the cut. Don't cut exactly at the clamp, use a grinder and grind up to the clamp to keep the end of the tube true.
Re: Cutting housing ends, what to use? [Re: PLUM BAD] #203575
01/25/09 12:37 AM
01/25/09 12:37 AM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
A lathe, but youll need a big one......and the proper supports/tooling.
Sure makes nice cuts though.
Re: Cutting housing ends, what to use? [Re: PLUM BAD] #203576
01/25/09 01:58 AM
01/25/09 01:58 AM
dave571 Offline
dave571  Offline
That's a good idea man!
Re: Cutting housing ends, what to use? [Re: dave571] #203577
01/25/09 02:13 AM
01/25/09 02:13 AM
IL
DRAGRCR632 Offline
super street
DRAGRCR632  Offline
super street
IL
bandsaw
LRT
Re: Cutting housing ends, what to use? [Re: DRAGRCR632] #203578
01/25/09 05:04 AM
01/25/09 05:04 AM
TMP66 Offline
TMP66  Offline
I prefer a horizontal bandsaw. Nice slow, clean square cut.
Chop saws work but tend to flex and flare out at the end of the cut.
Re: Cutting housing ends, what to use? [Re: 9 Sec Phill] #203579
01/25/09 04:27 PM
01/25/09 04:27 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I use a horizontal band saw and then true up the ends in a lathe.
Re: Cutting housing ends, what to use? [Re: John_Kunkel] #203580
01/25/09 04:34 PM
01/25/09 04:34 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I use a pipe cutter to put a GOOD line in the tube
then use my horizonal saw... the blade tracks nice
and straight on the line.... no need to dress the end
other than the burr
Re: Cutting housing ends, what to use? [Re: MR_P_BODY] #203581
01/25/09 04:40 PM
01/25/09 04:40 PM
Diego-Town, CA
Diego_Ted Offline
Diego_Ted  Offline
Diego-Town, CA
we used a chop saw!
Re: Cutting housing ends, what to use? [Re: 9 Sec Phill] #203582
03/02/09 10:20 AM
03/02/09 10:20 AM
Amarillo, Texas
BBR Offline
BBR  Offline
Amarillo, Texas
I just used a large pipe cutter the other day:
Beginning the cut.
Close up.
Finished cut.
RMRW 2018
RMRW 2020
Re: Cutting housing ends, what to use? [Re: BBR] #203583
03/02/09 10:30 AM
03/02/09 10:30 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
Beginning the cut.
Close up.
Finished cut.
same thing I did!
It might be a good idea to clean the housing around where the wheel rides to maintain an accurate cut, but -- thats the ticket for a square cut IMO
