Re: Cutting housing ends, what to use?
[Re: slantzilla]
#203572
01/25/09 12:16 AM
01/25/09 12:16 AM
Posts: 7,131 Amarillo, Texas
BBR
Amarillo, Texas
I've also heard of guys using a large pipe cutter. HFT --> No. 3 Pipe Cutter
Drag Week 2011 - 77th place - DD Drag Week 2012 - 2nd place SRBB N/A Drag Week 2014 - Kapooya RMRW 2018 RMRW 2020
[Re: PLUM BAD]
#203575
01/25/09 12:37 AM
01/25/09 12:37 AM
Posts: 4,384 Madison Wi
NTOLERANCE
Madison Wi
A lathe, but youll need a big one......and the proper supports/tooling.
Sure makes nice cuts though.
[Re: PLUM BAD]
#203576
01/25/09 01:58 AM
01/25/09 01:58 AM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
and a large hose clamp to mark the cut. Don't cut exactly at the clamp, use a grinder and grind up to the clamp to keep the end of the tube true.
That's a good idea man!
[Re: dave571]
#203577
01/25/09 02:13 AM
01/25/09 02:13 AM
Posts: 525 IL
DRAGRCR632
super street
super street
IL
[Re: 9 Sec Phill]
#203579
01/25/09 04:27 PM
01/25/09 04:27 PM
Posts: 25,849 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I use a horizontal band saw and then true up the ends in a lathe.
[Re: John_Kunkel]
#203580
01/25/09 04:34 PM
01/25/09 04:34 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I use a pipe cutter to put a GOOD line in the tube then use my horizonal saw... the blade tracks nice and straight on the line.... no need to dress the end other than the burr
[Re: 9 Sec Phill]
#203582
03/02/09 10:20 AM
03/02/09 10:20 AM
BBR
Amarillo, Texas
I just used a large pipe cutter the other day: Beginning the cut. Close up. Finished cut.
[Re: BBR]
#203583
03/02/09 10:30 AM
03/02/09 10:30 AM
Posts: 11,179 Atco NJ
DJVCuda
Atco NJ
Beginning the cut.
Close up.
Finished cut.
same thing I did! It might be a good idea to clean the housing around where the wheel rides to maintain an accurate cut, but -- thats the ticket for a square cut IMO
