Transmission Fluid Flush/Filter. #203400
01/24/09 09:03 PM
01/24/09 09:03 PM
The Thumb O' Michigan
Fluffy Offline OP
Automotive STD Guy
Fluffy  Offline OP
Automotive STD Guy
How long is too long before just not doing it? There's 130k on the vehicle now, and it's been had since 70k. Should the fluid/filter be done or would I be headed down the road of tearing it up faster?
Re: Transmission Fluid Flush/Filter. [Re: Fluffy] #203401
01/24/09 09:19 PM
01/24/09 09:19 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
Is this a tow vehicle ? .. what does the fluid look like now?
And from what I have heard .... those flush-jobs are most-times a total and complete waste of money.
Re: Transmission Fluid Flush/Filter. [Re: dOc !] #203402
01/24/09 09:21 PM
01/24/09 09:21 PM
Fluffy Offline OP
Automotive STD Guy
Fluffy  Offline OP
Automotive STD Guy
Nah, it's just a daily driver, no towing. I have to check the fluid in the morning.
It's not mine, but it doesn't have shifting problems or anything. I'd just like to prolong the life if possible.
Re: Transmission Fluid Flush/Filter. [Re: Fluffy] #203403
01/24/09 09:35 PM
01/24/09 09:35 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
I do the service every 30K, every 15K if I tow with it.
Re: Transmission Fluid Flush/Filter. [Re: Fluffy] #203404
01/24/09 11:30 PM
01/24/09 11:30 PM
Arlington, Texas
earlybee Offline
earlybee  Offline
Arlington, Texas
130k miles, leave it alone.
Re: Transmission Fluid Flush/Filter. [Re: Fluffy] #203405
01/24/09 11:50 PM
01/24/09 11:50 PM
I remember that thread on changing trans fluid but I've never lost sleep because I was changing fluids(on anything) too often. renews additives/detergents/flushes contaminates/dirt. Change it!
Re: Transmission Fluid Flush/Filter. [Re: RapidRobert] #203406
01/24/09 11:52 PM
01/24/09 11:52 PM
Fluffy Offline OP
Automotive STD Guy
Fluffy  Offline OP
Automotive STD Guy
If it's a little dirty, I'm more concerned for whatever reason adding new fluid will just make it slip or what not.
Re: Transmission Fluid Flush/Filter. [Re: Fluffy] #203407
01/25/09 01:35 AM
01/25/09 01:35 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
On a stocker daily driver, if the fluid's clean I don't change it unless the trans leaks. Drove transmissions that've been sitting in the bush for 20 years on their original fluid.
Re: Transmission Fluid Flush/Filter. [Re: Fluffy] #203408
01/25/09 10:15 AM
01/25/09 10:15 AM
Pizza Bucket
snuggles Offline
snuggles  Offline
Pizza Bucket
I would leave it. Last one I did the trans went a couple days after.
Re: Transmission Fluid Flush/Filter. [Re: Fluffy] #203409
01/25/09 11:45 AM
01/25/09 11:45 AM
MNobody Offline
MNobody  Offline
I changed the trans filter on my van at about 115,000, the fluid was dark red, not brown, i added new fluid to top it off and i've got another 10,000 on it now with no issues. I was nervous flushing the whole system as i've heard bad things about doing it on older vehicles and i don't think the fluid had ever been changed before.
Re: Transmission Fluid Flush/Filter. [Re: Fluffy] #203410
01/25/09 12:11 PM
01/25/09 12:11 PM
St Louis, Missouri
Runnin74 Offline
Runnin74  Offline
St Louis, Missouri
Just had the van (01 Caravan) done before Christmas and it has 130k miles. I bought the filter and fluid and and had an independent shop do the change. I had them just change the fluid - no flush. It has been fine. No problems. I will do it myself in the future, but I had to go on the road and didn't have the time.
Re: Transmission Fluid Flush/Filter. [Re: Runnin74] #203411
01/25/09 11:00 PM
01/25/09 11:00 PM
Missouri
convertriple Offline
super gas
super gas
Missouri
I went about 80000 miles between changes on my old driver after I bought it at 111,xxx. I was nervous, but I changed it at about 190,xxx and it was still going at 267,xxx when I sold it.
Re: Transmission Fluid Flush/Filter. [Re: convertriple] #203412
01/25/09 11:39 PM
01/25/09 11:39 PM
SE Michigan
farmington Offline
mopar addict
farmington  Offline
mopar addict
SE Michigan
problem with the flush is it gets all of the crap that has settled in the pan circulating and that can cause problems down the line. If you want to change it and change the filter, that's ok. don't flush.
Re: Transmission Fluid Flush/Filter. [Re: farmington] #203413
01/26/09 03:19 AM
01/26/09 03:19 AM
I always flush mine myself and this flush won't stir crap up but change the filter first anyway. Take the pressure line off by the cooler, trace the front line on the trans, and put a clear hose on it and have it dump in a bucket. Start it up and keep adding fluid until it comes out clear. It's better to run it in neutral as it circulates through the converter that way.
