Will new Challenger wheels fit old 4.5 bolt circle #203329
01/24/09 07:46 PM
01/24/09 07:46 PM
Ohio
V
viperakron Offline OP
V
Ohio
I think the new Challenger is 115mm bolt circle. The old one works out to around 114.3mm??? Is it close enough to work? Anyone try this.
Re: Will new Challenger wheels fit old 4.5 bolt circle [Re: viperakron] #203330
01/24/09 10:12 PM
01/24/09 10:12 PM
Ohio
V
V
Ohio
Re: Will new Challenger wheels fit old 4.5 bolt circle [Re: viperakron] #203331
01/24/09 11:41 PM
01/24/09 11:41 PM
WV.
Challenger_Nut Offline
WV.
Yes 114.3 and 4.5 are the same. Don't know what kind of clearance issues you would have with them. Get the offset numbers for them and go from there. I pesonally do not like 20 inchers on the the Classic Challenger.
Re: Will new Challenger wheels fit old 4.5 bolt circle [Re: Challenger_Nut] #203332
01/25/09 09:49 AM
01/25/09 09:49 AM
Ohio
V
V
Ohio
Anybody actually bolted the new wheel on an old Mopar? 114.3 to 115 is close but will it fit?
Re: Will new Challenger wheels fit old 4.5 bolt circle [Re: viperakron] #203333
01/25/09 10:06 AM
01/25/09 10:06 AM
Lithonia, Ga
3
36PLYM Offline
36PLYM  Offline
Lithonia, Ga
I have the new 17 inch Magnum wheels on a rearend from a 68 Coronet that is on my 36 Plymouth. No problems.
36 Plymouth Coupe
318 w/360 heads
518 trans
8 3/4 rear
Ga. Tech BCE'78
Re: Will new Challenger wheels fit old 4.5 bolt circle [Re: 36PLYM] #203334
01/25/09 11:00 AM
01/25/09 11:00 AM
Central NC
gch Online content
gch  Online Content
Central NC
My choice is the base v6 challenger's 17" aluminum wheels.I am going to try and pick up a take off set at the dealer where someone has upgraded.They appear to be a little narrower so they may not have as much offset like most of the newer cars.
Re: Will new Challenger wheels fit old 4.5 bolt circle [Re: Challenger_Nut] #203335
01/25/09 11:24 AM
01/25/09 11:24 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
I don't like them on anything.
Re: Will new Challenger wheels fit old 4.5 bolt circle [Re: MoparforLife] #203336
01/25/09 12:05 PM
01/25/09 12:05 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Smaller diameter wheels won't fit many new cars. Big rotors require big wheels.
Re: Will new Challenger wheels fit old 4.5 bolt circle [Re: DoctorDiff] #203337
01/25/09 12:27 PM
01/25/09 12:27 PM
Upper Midwest
Upper Midwest
I realize that but then and rubber band tires are still fugly. Espeicially when tried/used on an older car that they don't belong on.
Re: Will new Challenger wheels fit old 4.5 bolt circle [Re: MoparforLife] #203338
01/25/09 12:36 PM
01/25/09 12:36 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I have 07 chgarger wheels on my 68 cuda. They have lots of back spaceing, I have an early B-body rear in my car and they fit perfect on the rear.
On the front I have a 75 duster disc set up, they would not sit flush against the hub area. I had to machine the front rotors hub down to fit inside the wheels hub area and even after that I had to run a 7/32s spacer. I went through all that effort to make them fit like that because I wanted them hub centered and because they look great, help cornering, I got them cheap. I could not get a set of 15 inch ralleys for that cheap.
Re: Will new Challenger wheels fit old 4.5 bolt circle [Re: HotRodDave] #203339
01/25/09 12:40 PM
01/25/09 12:40 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Oh yeah, I have to install the front grease cap AFTER I install the front wheel. No center cap.
Steel wheels would have bolted on the front and rear.
Since it is a slightly different bolt pattern it is very important to make sure you get them hub centered.
Re: Will new Challenger wheels fit old 4.5 bolt circle [Re: MoparforLife] #203340
01/25/09 01:05 PM
01/25/09 01:05 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
People have called my pickups "fugly" since the late 1980s when I started running 19.5" truck wheels. Tire height combined with a short side wall and F load rating helps the gear ratio and provides a stable ride, especially when loaded.
Likewise, a balanced package of big brakes, big wheels and stiff sidewalls enhances a car's handling and braking.
I'm glad more vehicles come standard with this configuration.
Re: Will new Challenger wheels fit old 4.5 bolt circle [Re: MoparforLife] #203341
01/25/09 01:05 PM
01/25/09 01:05 PM
Fairfield, Ohio
holtzdog55 Offline
holtzdog55  Offline
Fairfield, Ohio
Finally Done....BEERS!!!
Re: Will new Challenger wheels fit old 4.5 bolt circle [Re: holtzdog55] #203342
01/25/09 07:58 PM
01/25/09 07:58 PM
Ohio
V
V
Ohio
Better get used to it. Pro Touromg cars are the hot rods of the future. There is a fine balance to the sidewall height as it relates to the stance of the car. 17s and 18s can make an old muscle car look like it's in the next generation. It's all personal preference, thats what make the world go round.
Re: Will new Challenger wheels fit old 4.5 bolt circle [Re: viperakron] #203343
01/25/09 08:03 PM
01/25/09 08:03 PM
Gloucester,VA STOP MOVING HERE
RangerDan440 Offline
I love to get a set of the 18X8 steelies the Charger police cars come with
68 Valiant 408
69 Charger 318
69 Cougar 351W
70 Torino GT 351C
71 Country Squire 351W
71 Road Runner 440+6
71 Satellite sedan 318
73 Duster 318
73 Challenger 383
77 Grand Prix 455
83 Malibu 9C1 383
84 Delta 88 403
87 Grand National
96 Ram 360
09 Crown Vic
10 Challenger R/T M6
15 Challenger Hellcat M6
Re: Will new Challenger wheels fit old 4.5 bolt circle [Re: RangerDan440] #203344
01/25/09 08:10 PM
01/25/09 08:10 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Didn't Mopork have some of them ?
Re: Will new Challenger wheels fit old 4.5 bolt circle [Re: HotRodDave] #203345
01/27/09 12:07 AM
01/27/09 12:07 AM
california
fyve0 Offline
fyve0  Offline
california
what dia did you turn the hubs to?hub centric? dont the wheel studs bring it into center?newbie to mopars any suggestions i am trying to put them on my 70 rr thanx Mike
Re: Will new Challenger wheels fit old 4.5 bolt circle [Re: fyve0] #203346
01/27/09 12:54 AM
01/27/09 12:54 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
The hub was too long, I machined it shorter and put a 45 degree bevel on the end so it would fit inside the wheel.
Normaly wheels are centered on the hub not the studs. The bolt pattern on old mopars is 5 lugs on a 4.5 inch circle or about .7 MM smaller than the new mopar pattern witch if I recall corectly is 115MM so they can be slightly off center if one lug was tightened first or slightly more or less than the others, that is why it is important to run a thin enough spacer to keep the hub in the centering ring of the wheels big center hole. I have no vibration now at 130mph.
Re: Will new Challenger wheels fit old 4.5 bolt circle [Re: HotRodDave] #203347
01/28/09 10:31 AM
01/28/09 10:31 AM
MI
marklock Offline
I tried too hard for a custom title
marklock  Offline
MI
Looks good to me. What size tires you got ?
