Re: Will new Challenger wheels fit old 4.5 bolt circle
[Re: viperakron]
#203330
01/24/09 10:12 PM
01/24/09 10:12 PM
Posts: 833 Ohio
viperakron
Ohio
[Re: viperakron]
#203333
01/25/09 10:06 AM
01/25/09 10:06 AM
Posts: 251 Lithonia, Ga
36PLYM
Lithonia, Ga
I have the new 17 inch Magnum wheels on a rearend from a 68 Coronet that is on my 36 Plymouth. No problems.
36 Plymouth Coupe 318 w/360 heads 518 trans 8 3/4 rear Ga. Tech BCE'78
[Re: Challenger_Nut]
#203335
01/25/09 11:24 AM
01/25/09 11:24 AM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
I pesonally do not like 20 inchers on the the Classic Challenger.
I don't like them on anything.
[Re: DoctorDiff]
#203337
01/25/09 12:27 PM
01/25/09 12:27 PM
MoparforLife
Upper Midwest
Smaller diameter wheels won't fit many new cars. Big rotors require big wheels.
I realize that but then and rubber band tires are still fugly. Espeicially when tried/used on an older car that they don't belong on.
[Re: MoparforLife]
#203338
01/25/09 12:36 PM
01/25/09 12:36 PM
Posts: 12,422 Kalispell Mt.
HotRodDave
Kalispell Mt.
I have 07 chgarger wheels on my 68 cuda. They have lots of back spaceing, I have an early B-body rear in my car and they fit perfect on the rear.
On the front I have a 75 duster disc set up, they would not sit flush against the hub area. I had to machine the front rotors hub down to fit inside the wheels hub area and even after that I had to run a 7/32s spacer. I went through all that effort to make them fit like that because I wanted them hub centered and because they look great, help cornering, I got them cheap. I could not get a set of 15 inch ralleys for that cheap.
[Re: HotRodDave]
#203339
01/25/09 12:40 PM
01/25/09 12:40 PM
HotRodDave
Kalispell Mt.
Oh yeah, I have to install the front grease cap AFTER I install the front wheel. No center cap.
Steel wheels would have bolted on the front and rear.
Since it is a slightly different bolt pattern it is very important to make sure you get them hub centered.
[Re: holtzdog55]
#203342
01/25/09 07:58 PM
01/25/09 07:58 PM
Posts: 833 Ohio
viperakron
Ohio
Better get used to it. Pro Touromg cars are the hot rods of the future. There is a fine balance to the sidewall height as it relates to the stance of the car. 17s and 18s can make an old muscle car look like it's in the next generation. It's all personal preference, thats what make the world go round.
[Re: viperakron]
#203343
01/25/09 08:03 PM
01/25/09 08:03 PM
Posts: 12,861 Gloucester,VA STOP MOVING HERE
RangerDan440
I love to get a set of the 18X8 steelies the Charger police cars come with
68 Valiant 408 69 Charger 318 69 Cougar 351W 70 Torino GT 351C 71 Country Squire 351W 71 Road Runner 440+6 71 Satellite sedan 318 73 Duster 318 73 Challenger 383 77 Grand Prix 455 83 Malibu 9C1 383 84 Delta 88 403 87 Grand National 96 Ram 360 09 Crown Vic 10 Challenger R/T M6 15 Challenger Hellcat M6
[Re: RangerDan440]
#203344
01/25/09 08:10 PM
01/25/09 08:10 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
Didn't Mopork have some of them ?
[Re: fyve0]
#203346
01/27/09 12:54 AM
01/27/09 12:54 AM
HotRodDave
Kalispell Mt.
The hub was too long, I machined it shorter and put a 45 degree bevel on the end so it would fit inside the wheel.
Normaly wheels are centered on the hub not the studs. The bolt pattern on old mopars is 5 lugs on a 4.5 inch circle or about .7 MM smaller than the new mopar pattern witch if I recall corectly is 115MM so they can be slightly off center if one lug was tightened first or slightly more or less than the others, that is why it is important to run a thin enough spacer to keep the hub in the centering ring of the wheels big center hole. I have no vibration now at 130mph.
[Re: HotRodDave]
#203347
01/28/09 10:31 AM
01/28/09 10:31 AM
Posts: 560 MI
marklock
I tried too hard for a custom title
MI
Looks good to me. What size tires you got ?
