Page 3 of 6 1 2 3 4 5 6
Re: 1969 340... Blue or Turquoise? [Re: JRepucci] #2032269
03/16/16 11:26 AM
03/16/16 11:26 AM
Canada
Maxwellwedge Offline
Canada
Originally Posted By JRepucci
That's my car....that's 100% original paint on the engine.....the negative cables WERE installed on the engine when painted....as evidenced by the lack of paint on the valve cover where the cable layed accross. That is an Oregon car....for some reason every car I have ever bought that was from there are super clean and rust free.......you should see the bottom of this thing. Scott - yes lot's of cleaning and degreasing etc - but the car is a gem. Concerning the blue engine.....It is a late build if that has any bearing....June 25th. I remember the orange motored Dart that went through OE a few years back.....I still am unconvinced about that one.
Cheers
Jim B.
Re: 1969 340... Blue or Turquoise? [Re: JRepucci] #2032273
03/16/16 11:33 AM
03/16/16 11:33 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Agreed Jim, very nice car and an obvious survivor with some great details. As far as the battery cable specifically, yes, I have seen that on 69's, but it varied through the 340 production years. For example, every original (orange motor) 71 I've seen, the neg cable was added after paint. BTW, I'm also undecided, doubtful of the orange motor 70 simply because the full history of the car is unknown.
In summary, 340 engine details changed A LOT from 68-73. IMO there's still more to be discovered on them, survivors are few and far between but I still learn more with every one I see.
Re: 1969 340... Blue or Turquoise? [Re: Maxwellwedge] #2032548
03/16/16 06:36 PM
03/16/16 06:36 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Cheers
Jim B.
On the bat cable I meant it would not be painted again even if the engine was removed, rebuilt and repainted
Re: 1969 340... Blue or Turquoise? [Re: JRepucci] #2032755
03/16/16 11:39 PM
03/16/16 11:39 PM
MO
cdp Offline
cdp  Offline
MO
My 69 340 swinger is about 9000 serial numbers later than MaxwellWedge, and the motor was for sure blue. Even though the engine had been pulled and modified, I bought the original valve covers, oil pan, intake, manifolds, etc... 15 years before hand...and all were blue, rather than the lighter turquise. Looking at the build sheet, is the 709 the build date. Order number 176545.
Re: 1969 340... Blue or Turquoise? [Re: JRepucci] #2032791
03/17/16 12:09 AM
03/17/16 12:09 AM
MO
cdp Offline
cdp  Offline
MO
340 4spd short block I picked up from last year.
Re: 1969 340... Blue or Turquoise? [Re: JRepucci] #2032830
03/17/16 12:53 AM
03/17/16 12:53 AM
Sacramento,California
JRepucci Offline OP
JRepucci  Offline OP
Who sells the most authentic blue paint? Badelson?
and I also need a 4611 AVS...
Re: 1969 340... Blue or Turquoise? [Re: JRepucci] #2032834
03/17/16 12:59 AM
03/17/16 12:59 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I don't know if Frank makes a standard blue but if he does it's probably right on the money. In your case you might consider going to the paint store with an original sample for a color match, get it mixed in single stage PPG Delstar DAR Acrylic Enamel.
*The only 69 carb I have is a 4611SA D9
Re: 1969 340... Blue or Turquoise? [Re: ScottSmith_Harms] #2032955
03/17/16 09:58 AM
03/17/16 09:58 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I have a couple of 4611's but they were on the shelf when my garage burned. whiney So a pattern starts to emerge, we have blue engine paint on 6/25 and 7/07, start searching for documents in that time period to see if there was really a TSB for the change... work
JB Rhinehart, Realist
A-Body's RULE!
Re: 1969 340... Blue or Turquoise? [Re: JRepucci] #2033019
03/17/16 11:40 AM
03/17/16 11:40 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Jim, I can sometimes save burned carbs as long as the main castings are not visibly melted. Unfortunately the car these were on burnt to the ground. these were roasted, had melted floats, shafts frozen solid, but I managed to save these carbs.
Re: 1969 340... Blue or Turquoise? [Re: JRepucci] #2033087
03/17/16 01:09 PM
03/17/16 01:09 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Those were a good save!
Re: 1969 340... Blue or Turquoise? [Re: ScottSmith_Harms] #2033173
03/17/16 03:02 PM
03/17/16 03:02 PM
Canada
Canada
Frank doesn't have the blue unfortunately.....he does have the turquoise....so It's looking like SPD's may possibly be the determining factor on color.
My buddy picked up an early 69 Swinger 340 and according to Moparo.....who is doing the car for him.....he has found a lot of traces of turquoise on that engine.
That engine plant did not do Hemi's or BB's.....so there would be no need for them to have any orange paint around.....in 69 anyway.
Re: 1969 340... Blue or Turquoise? [Re: JRepucci] #2034619
03/19/16 06:47 PM
03/19/16 06:47 PM
JRepucci Offline OP
JRepucci  Offline OP
I now know of another July SPD Dart with blue engine
Re: 1969 340... Blue or Turquoise? [Re: JRepucci] #2035104
03/20/16 03:11 PM
03/20/16 03:11 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
If you can document or have significant/sufficeint evidence for an oddity then go with it, if no information exist to support your claim on the subject car then go with the documented norm. twocents
I think there is sufficent evidence to say this car came out of the box blue.
Careful, your character's showing!
Re: 1969 340... Blue or Turquoise? [Re: Rhinodart] #2036138
03/22/16 12:12 AM
03/22/16 12:12 AM
Canada
demon Offline
demon  Offline
Canada
Originally Posted By Rhinodart
There is always the "never say never" with any Chrysler product, but once again a very late built car. I have seen a 69 Swinger 340 with bucket seats, fender turn signals, and rocker moldings that was a July built car and those options were not available on Swinger 340's. Could a few examples have been painted blue because turquoise was being phased out? Probably, but the vast MAJORITY were painted turquoise and Chrysler documentation still TRUMPS a few examples found in the wild... twocents Can anyone find any TSB's that show a late-year switch to blue? I certainly haven't. scope
Rocker mouldings and turn indicators were available on 340 69 Swingers. My own 69 was a dealer demonstrator, highly optioned car and had both of those options. Original paint car with Build sheet
Re: 1969 340... Blue or Turquoise? [Re: demon] #2036302
03/22/16 10:13 AM
03/22/16 10:13 AM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
What is the SPD? shruggy You would have to have A01 light package for the indicators, what does the broadcast sheet say for those parts? scope
A-Body's RULE!
Re: 1969 340... Blue or Turquoise? [Re: ScottSmith_Harms] #2066178
05/02/16 10:10 PM
05/02/16 10:10 PM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
How about red. Here is a picture of the ground wire off a 69 340 Formula S. No doubt the engine was red originally as it had never tinkered with until recently.
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
Re: 1969 340... Blue or Turquoise? [Re: sixpackbee] #2066409
05/03/16 10:29 AM
05/03/16 10:29 AM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
It looks to be all about SPD's, when was that car built? work
A-Body's RULE!
Re: 1969 340... Blue or Turquoise? [Re: Rhinodart] #2066458
05/03/16 12:13 PM
05/03/16 12:13 PM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
Jim, The SPD is 7/28. Quite possibly the first 340 built for 69. The car has a very low VIN.
1959 Bugeye Sprite
1971 MG Midget
Re: 1969 340... Blue or Turquoise? [Re: sixpackbee] #2067635
05/05/16 10:02 AM
05/05/16 10:02 AM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Thanks, I will check my TSB's to see what the date was that they were issued. work
A-Body's RULE!
Re: 1969 340... Blue or Turquoise? [Re: JRepucci] #2067671
05/05/16 11:33 AM
05/05/16 11:33 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
My thoughts on pre production cars are that almost anything goes. I have seen some very odd stuff on "pilot" cars. IMO they should be restored to retain as many of original details as can be found and enjoyed by all as an example of what was done when a new car was brought into the fray before regular production began. Duplicating or referencing these oddball details when restoring a regular production car would be a mistake.
*Restoring a rough pilot car can be a daunting task since there is nothing to reference in terms of their actual original details, each is truly a one of a kind.
