Page 1 of 3 1 2 3
Finally, REDEMPTION. Dyno Results!!!! #203268
01/24/09 07:41 PM
01/24/09 07:41 PM
Mn.
daytona5812 Offline OP
Mn.
As most of you know, my last dyno session ended in disaster. Well, it's been a long road back,{ 1 year}, & I finally got the new motor done. Last motor was a 572. This time I went to a 606 cu in.
Went to the dyno today, & things turned out alot better. I'm so happy I could scream. I was hoping for 1020-1050 hp.
What I got was 1124 hp at 7200 & 902 tq at 5700.
Can't wait till summer. Vern!!!
Re: Finally, REDEMPTION. Dyno Results!!!! [Re: daytona5812] #203269
01/24/09 07:47 PM
01/24/09 07:47 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Congrats. Suprises are always nice. Congrats. Whats the combo ??
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: Finally, REDEMPTION. Dyno Results!!!! [Re: daytona5812] #203270
01/24/09 07:51 PM
01/24/09 07:51 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
AWSOME!exceeding the goal feels sweet huh?! almost!makes the wait worth it.
Re: Finally, REDEMPTION. Dyno Results!!!! [Re: sunroofgtx] #203271
01/24/09 08:18 PM
01/24/09 08:18 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
ya man... some specs would be awesmoe here
-How did you get 606 (bore, stroke, block)
-cam?
-heads?
-comp?
Good job on getting that much power
Re: Finally, REDEMPTION. Dyno Results!!!! [Re: sunroofgtx] #203272
01/24/09 08:26 PM
01/24/09 08:26 PM
Mn.
Mn.
It's a Indy Max Alum block 4.508 bore
Callies 4.75 crank
Grodin alum rods
CP flat top pistons
Jessel belt drive
Fred Brewer heads
Custom made sheet metal intake by ZONKZ.com
Two 850 dominators
MSD crank trigger
NRC offset dist
Lunati cam .875 in .800 ex dur @ .50 290 in 307 ex
T&D 1.75 rockers
Matton 7/16 push rods
Re: Finally, REDEMPTION. Dyno Results!!!! [Re: daytona5812] #203273
01/24/09 08:28 PM
01/24/09 08:28 PM
ELYRIA,OH
ELYRIA,OH
man those are great BSFC#'s!
Re: Finally, REDEMPTION. Dyno Results!!!! [Re: daytona5812] #203274
01/24/09 08:29 PM
01/24/09 08:29 PM
Mn.
Mn.
Oh yea, I almost forgot,
Custom set of Firecore plug wires!!!
Re: Finally, REDEMPTION. Dyno Results!!!! [Re: daytona5812] #203275
01/24/09 08:31 PM
01/24/09 08:31 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
any pics ?
do you have a part number on the 850 dominaters ?
1.39 9.85 - 137 mph
Re: Finally, REDEMPTION. Dyno Results!!!! [Re: blownzoom440] #203276
01/24/09 08:34 PM
01/24/09 08:34 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I was going to say the same think about the brake specifics......AWESOME and definately dialed in. This thing will fly no matter what you put it in.
Re: Finally, REDEMPTION. Dyno Results!!!! [Re: Ari440] #203277
01/24/09 08:48 PM
01/24/09 08:48 PM
Mn.
Mn.
The carbs are 15 yr old pro-stock carbs. I'm borrowing them from the guy that made my intake. I can look for a part #, but there are some mods made to those carbs that I have never seen before.
Re: Finally, REDEMPTION. Dyno Results!!!! [Re: daytona5812] #203278
01/24/09 09:02 PM
01/24/09 09:02 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Nice numbers 1.85 hp per ci
Re: Finally, REDEMPTION. Dyno Results!!!! [Re: daytona5812] #203279
01/24/09 09:05 PM
01/24/09 09:05 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
is that a NRC offset distributer
GOOD LUCK !
1.39 9.85 - 137 mph
Re: Finally, REDEMPTION. Dyno Results!!!! [Re: MR_P_BODY] #203280
01/24/09 09:09 PM
01/24/09 09:09 PM
gregsdart Offline
gregsdart  Offline
Wow, Vern, thats some motor ya got there! Those heads really work with the right parts around em! Congrats!! What do you expect? 7.80s?
Re: Finally, REDEMPTION. Dyno Results!!!! [Re: gregsdart] #203281
01/24/09 09:11 PM
01/24/09 09:11 PM
gregsdart Offline
gregsdart  Offline
I have heard you can judge a set of wedge heads by the length of the valves. Brewer valves come in a broom handle box!!
Re: Finally, REDEMPTION. Dyno Results!!!! [Re: Ari440] #203282
01/24/09 09:12 PM
01/24/09 09:12 PM
Mn.
Mn.
Yes it's a NRC dist. Are you implying there is something wrong with the dist. or wishing me good luck with the new motor?
Re: Finally, REDEMPTION. Dyno Results!!!! [Re: daytona5812] #203283
01/24/09 09:16 PM
01/24/09 09:16 PM
NC
440Jim Offline
440Jim  Offline
NC
That is some serious normally aspirated horsepower. Nice job. What kind of flow do those heads go?
Re: Finally, REDEMPTION. Dyno Results!!!! [Re: daytona5812] #203284
01/24/09 09:18 PM
01/24/09 09:18 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
GOOD LUCK WITH THE MOTER
just asking what distributer it is
1.39 9.85 - 137 mph
Re: Finally, REDEMPTION. Dyno Results!!!! [Re: gregsdart] #203285
01/24/09 09:19 PM
01/24/09 09:19 PM
Mn.
Mn.
Hi Greg, long time no see. I'm hoping to run close to that. I went 8.08 at 176 w/1028 hp @ 2570 lbs. Now with less weight [ alum block] & a little more hp, it should be close to that.
Re: Finally, REDEMPTION. Dyno Results!!!! [Re: Ari440] #203286
01/24/09 09:20 PM
01/24/09 09:20 PM
Mn.
Mn.
Sorry, I read it wrong. Thanks, Vern!!
Re: Finally, REDEMPTION. Dyno Results!!!! [Re: 440Jim] #203287
01/24/09 09:25 PM
01/24/09 09:25 PM
Mn.
Mn.
I sent the heads to Barton Heads in Oklahoma & he messaged them a little.
They flow 479 in & 409 ex.
Page 1 of 3 1 2 3
