Pistol grip shifter? #2031902
03/15/16 09:40 PM
03/15/16 09:40 PM
GA
Gerald l Offline OP
Gerald l  Offline OP
GA
Does anyone make a pistol grip style shifter for a 68 roadrunner?
Re: Pistol grip shifter? [Re: Gerald l] #2031907
03/15/16 09:45 PM
03/15/16 09:45 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
You just use the one used in a 70 RR assuming you have a hurst shift box. Early 68s had Inland shifters
Re: Pistol grip shifter? [Re: Morty426] #2032422
03/16/16 03:16 PM
03/16/16 03:16 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The '68 Hurst mechanism has a longer throw, pistol grip handle in a '68-'69 will usually put your knuckles close to or into the dash. Even with the '70 mechanism it's close.
Re: Pistol grip shifter? [Re: Gerald l] #2032579
03/16/16 07:07 PM
03/16/16 07:07 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
You might check with Brewer's or Passon and see what's available in different lever heights/shapes. Brewer's recently bought out Gunslinger and is supposedly tooling up different pistol grip levers, though Gunslinger's were for auto trans shifters.
As stated, the '70s had long levers with a lot of travel.
