Page 1 of 6 1 2 3 4 5 6
Good day for (street) car at the track! *New best today* #2030241
03/13/16 02:16 PM
03/13/16 02:16 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
We only got 3 passes at test and tune. Light mist kept holding things up.
Keep in mind this is a street car with full interior, 5/16 fuel line and pump gas. I ran it the way I drove it to the track. Didn't change air pressure or anything!
Combo:
'63 Dodge 330 Sedan
505" 440 block with 4.25 stroke and 7.1" Molnar rods and crank.
10.5 CR
Modern Cylinder Head ported Stealth heads
Howards hydraulic roller .545 lift and 235/241 @ .050 duration installed straight up with 1.5 Crane rockers.
Holley Street Dominator intake with 1/2" spacer
Demon 850 double pumper
2800 stall converter
3.55 gears
3" full exhaust with Dynomax Ultra Flows
275/60/15 MT Pro's
6 cylinder bars and SS springs. Monroe street shocks.
Could only hook off idle. That was the best pass after touching the Rev limiter in 1st and 2nd (6k rpm)
60 ft. 1.73
330 4.91
1/8th 7.54
1/8th mph 92.9
1000ft. 9.82
1000mph 106
1/4 mile 11.75
1/4 mile 117.16 mph
Feedback?
I plan on dropping the rear pressure to 14 psi next time and leaving with a little more rpm. 60ft. wasn't what I had hoped..
Re: Good day for (street) car at the track! [Re: GY3] #2030245
03/13/16 02:22 PM
03/13/16 02:22 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Not bad but I would definitely up the fuel line w/that many cubes............
Re: Good day for (street) car at the track! [Re: Thumperdart] #2030249
03/13/16 02:36 PM
03/13/16 02:36 PM
kansas
farmboy Offline
farmboy  Offline
kansas
We'll get him straitened out. CTB
Re: Good day for (street) car at the track! [Re: Thumperdart] #2030250
03/13/16 02:40 PM
03/13/16 02:40 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
Probably wouldn't hurt to go 3/8" line. laugh2
I plan on lowering the tire pressure, clamping the front segment of the springs a little more and taking the clamps off the rear. That way I can (hopefully) raise the launch rpm some.
It may get some 90/10 shocks up front to help, too!
Re: Good day for (street) car at the track! [Re: farmboy] #2030251
03/13/16 02:41 PM
03/13/16 02:41 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
Yep, gonna lean on the Godfather for some info...SOS!
Re: Good day for (street) car at the track! [Re: Thumperdart] #2030252
03/13/16 02:41 PM
03/13/16 02:41 PM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
iagree
You might want to try some adjustable shocks with the SS springs.
I run 16psi in my 275 ET Streets on a 8" wide wheel, SS Springs & CE 3 way shocks. 1.60 - 1.62 60'
72 Plymouth Roadrunner 11.08@123.25
Re: Good day for (street) car at the track! [Re: GY3] #2030259
03/13/16 02:51 PM
03/13/16 02:51 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
Nice!
What was the converter flashing to? Might have been hard to tell if there was tire spin.
Similar to my combo aside from the heads/cam:
493, ported -516 heads
530 lift solid FT, 260/266 @ 0.050, M1, 950 HP
full 3" exhaust
9.5" dynamic, 3.55's
325/50 Drag radial, Rancho single adjustable shocks
/6 bars 90-10's up front
Shift at 5500rpm
Last pass was:
60 ft. 1.601
330 4.669
1/8th 7.28
1/8th mph 93.57
1000ft. 9.570
1000mph NA
1/4 mile 11.519
1/4 mile 115.39 mph
Made a big difference going from non adjustable shocks to Rancho (Calvert) 9 ways. Couldn't justify DA shocks for a 11 second car... Went from burning the tires at anything above a high idle, to being able to leave at 3k foot braking.
You have a few tenths on the table if you can get it to launch.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: Good day for (street) car at the track! [Re: OUTLAWD] #2030263
03/13/16 02:55 PM
03/13/16 02:55 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
No idea on the convertor flash. I don't even have a tach in the car! shruggy grin
Re: Good day for (street) car at the track! [Re: farmboy] #2030265
03/13/16 02:56 PM
03/13/16 02:56 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I can...........and what`s CTB?
Re: Good day for (street) car at the track! [Re: Thumperdart] #2030268
03/13/16 02:59 PM
03/13/16 02:59 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
Our local car club that we started...
Re: Good day for (street) car at the track! [Re: GY3] #2030272
03/13/16 03:01 PM
03/13/16 03:01 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Gotcha............ thumbs
Re: Good day for (street) car at the track! [Re: Thumperdart] #2030284
03/13/16 03:23 PM
03/13/16 03:23 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Thats very good numbers for a first outing. up Congrats on doing good and getting out. beer That 117 mph is enough for solid 11.30's with good hook. Nice going. Ron
Re: Good day for (street) car at the track! [Re: GY3] #2030291
03/13/16 03:29 PM
03/13/16 03:29 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Sounds like a fun day at the track! up
Re: Good day for (street) car at the track! [Re: 383man] #2030299
03/13/16 03:39 PM
03/13/16 03:39 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
Thanks, Ron!
I think I can whittle it down a little.
I aspire to run hard and drive it everywhere like you do!
Re: Good day for (street) car at the track! [Re: GY3] #2030338
03/13/16 04:58 PM
03/13/16 04:58 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
Pics of LaFawnduh:
Re: Good day for (street) car at the track! [Re: GY3] #2030346
03/13/16 05:16 PM
03/13/16 05:16 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Not bad up at least your getting out
wave
Re: Good day for (street) car at the track! [Re: MR_P_BODY] #2030359
03/13/16 05:47 PM
03/13/16 05:47 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
wave
Everyone's cars run so good here I was a little hesitant to post.
I think it's a good start, though...
Re: Good day for (street) car at the track! [Re: GY3] #2030411
03/13/16 07:03 PM
03/13/16 07:03 PM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
Going to Indy swap meet and posts like this are what make me go work on my car to get it going. 470" stroker with mch done up stealth heads should be a bit quicker than my old ~8.8:1 383 I had in it that ran 14.5's.
So thanks for posting! Now off to set the motor in. Then gotta switch the 8 3/4 to the strange 60 and get a driveshaft made. Pretty excited!
Re: Good day for (street) car at the track! [Re: 68KillerBee] #2030602
03/13/16 10:49 PM
03/13/16 10:49 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
Haha, I have a Dana 60 waiting in the wings. May wait until Fall to see if I need to mini tub the car for traction. drive
I'll be at Mo-Kan April 9th for the Mopar event and then again for the HAMB drags. Come by and say Hi.
Re: Good day for (street) car at the track! [Re: GY3] #2030691
03/14/16 12:49 AM
03/14/16 12:49 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Thanks, Ron!
Thanks for the kind words. wave I was going to say that I run 3/8 fuel line and it seems to be more then enough for my combo with just an 850 DP. My son still has the 5/16 line on his Dart and it has run 11.40's @ 117 with the 5/16 line. Glad to see that cool 63 running good. up Ron
