Aluminum radiator for BB truck #2028574
03/10/16 03:11 PM
03/10/16 03:11 PM
Spahn Ranch
RMCHRGR Offline OP
RMCHRGR  Offline OP
Spahn Ranch
So my OE type 28" radiator leaks like a sieve. It rusted my brand new booster by spraying coolant all over the place. I've fixed it once already but it's time for a new one, no more fixing junk.
Anyone have any suggestions for an modern aluminum radiator on the cheap side? Basically just anything that fits and had the hose outlets in the correct positions for a BB.
Part #s help but just point me in the right direction.
Thanks for any input.
- Greg
'71 Duster
'72 Challenger
'17 Ram 1500
Re: Aluminum radiator for BB truck [Re: RMCHRGR] #2029346
03/11/16 06:57 PM
03/11/16 06:57 PM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
No one seems to be jumping in with suggestions, so I'll throw some ideas out there - but also say that 'cheap' is a relative term.
Champion Radiator has a number of aftermarket aluminum, down flow radiators. You should be able to find something that will fit with in/outs in the correct location: http://www.championradiators.com/
There are a number of options on ebay.
Summit racing sells universal cross flow units under $200 but may require you to fab mounting brackets of come up with a mounting system. I used one for my blown BB Duster for clearance reasons. http://www.70duster440.com/cooling.html
Re: Aluminum radiator for BB truck [Re: RMCHRGR] #2029421
03/11/16 09:20 PM
03/11/16 09:20 PM
Spahn Ranch
RMCHRGR Offline OP
RMCHRGR  Offline OP
Spahn Ranch
Thanks for the reply.
I imagine there are no 'bolt in' options which is why I am asking if anyone has found something that worked without too much fuss.
Of course cheap is a relative term here. Don't really want to spend $5-600 bones on something but maybe around $200-$250?
Fabbing up brackets is not a problem and I figured I'd be doing something like that but the less involved, the better.
I found Spectra CU889 which is $240 at R.A.
'71 Duster
'72 Challenger
'17 Ram 1500
Re: Aluminum radiator for BB truck [Re: RMCHRGR] #2030219
03/13/16 01:23 PM
03/13/16 01:23 PM
Marysville, WA
77ProStreet Offline
77ProStreet  Offline
Marysville, WA
There are a couple companies that make specific fit radiators for our dodge trucks for inexpensive. I've seen a few on Ebay.
Re: Aluminum radiator for BB truck [Re: RMCHRGR] #2030220
03/13/16 01:26 PM
03/13/16 01:26 PM
Marysville, WA
77ProStreet Offline
77ProStreet  Offline
Marysville, WA
http://i.ebayimg.com/00/s/MTYwMFgxNjAw/z/3BoAAOSwNSxU73hD/$_1.JPG
Re: Aluminum radiator for BB truck [Re: RMCHRGR] #2030811
03/14/16 11:19 AM
03/14/16 11:19 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I have a generic AFCO aluminum rad on my BB car. I just picked ones with inlets/outlets on the sides I wanted and put it together with some flex hose. Working great.
Re: Aluminum radiator for BB truck [Re: RMCHRGR] #2030910
03/14/16 02:08 PM
03/14/16 02:08 PM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
I've got a generic copper/steel rad in my '77 and have seen the cheapie aluminum radiators on ebay too.
Re: Aluminum radiator for BB truck [Re: RMCHRGR] #2031146
03/14/16 08:13 PM
03/14/16 08:13 PM
nj
JAMESDART Offline
JAMESDART  Offline
nj
I would be surprised if champion doesnt have a bolt in option
Re: Aluminum radiator for BB truck [Re: RMCHRGR] #2032025
03/16/16 12:10 AM
03/16/16 12:10 AM
Marion Illinois
72d100 Offline
72d100  Offline
Marion Illinois
Why wouldn't a 26 inch aluminum b body radiator bolt in?
Re: Aluminum radiator for BB truck [Re: 72d100] #2032078
03/16/16 01:03 AM
03/16/16 01:03 AM
Spahn Ranch
RMCHRGR Offline OP
RMCHRGR  Offline OP
Spahn Ranch
You know, I have a 26" small block radiator taking up space...
Maybe that flex hose idea could work in that situation.
'71 Duster
'72 Challenger
'17 Ram 1500
