Starting from scratch which head?
#2024540
03/04/16 04:17 PM
03/04/16 04:17 PM
Posts: 2,422 Pittsburgh PA
Eric
Pittsburgh PA
Putting a 499" low deck together for the Arrow. With the CNC Indy SR's that were on it the car had gone 5.53 @ 125 with a tenth in the timer. Well...I've been thinking of trying another head possibly. Looking at the Trick Flows and the Eddy Victors. Do you folks think there is a gain or a loss to using either of these compared to the SR's?
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Starting from scratch which head?
[Re: Eric]
#2024688
03/04/16 10:01 PM
03/04/16 10:01 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
I wouldn't really call 440-1s "big boy pants". I think that would be more like B1-MCs or possibly Predators. In my opinion, unless you go to a serious head, the gains over what you have now will be little compared to money spent. Are the SRs fully ported, with Max Wedge size ports? If not, that would be a bit of a gain and require only a manifold change
[Re: Eric]
#2024721
03/04/16 11:01 PM
03/04/16 11:01 PM
Posts: 4,207 New York
polyspheric
New York
You can almost buy an entire turbo setup for what a really good set of heads costs (including porting, manifold, rockers, etc.).
Boffin Emeritus
[Re: polyspheric]
#2024724
03/04/16 11:07 PM
03/04/16 11:07 PM
Thumperdart
State of confusion
You can almost buy an entire turbo setup for what a really good set of heads costs (including porting, manifold, rockers, etc.). Ya, ya, most just jump on the power adder wagon and go fast just like they SHOULD but he`s done well n/a which personally impresses me more but it`s not about me so,..................
[Re: polyspheric]
#2024732
03/04/16 11:20 PM
03/04/16 11:20 PM
Posts: 20,182 PA.
pittsburghracer
"Little"John
"Little"John
PA.
You can almost buy an entire turbo setup for what a really good set of heads costs (including porting, manifold, rockers, etc.). Eric runs the Super classes with the 4 tenths tree so a turbo isn't really the way to go
[Re: Eric]
#2024744
03/04/16 11:40 PM
03/04/16 11:40 PM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
SR heads ported to MW size are short about 40 hp from a good set of 440-1 heads. If you want to go reasonably fast on a budget, my guess is 440-1 heads fully ported with 2.25 intakes and stock rockers and an easy to live with cam that won't beat them to death would be my idea of what to do. You run super classes, so ultimate power is less important to you than being able to make a lot of passes between maintainance, right?
[Re: gregsdart]
#2024748
03/04/16 11:44 PM
03/04/16 11:44 PM
Monte_Smith
North Alabama
SR heads ported to MW size are short about 40 hp from a good set of 440-1 heads. If you want to go reasonably fast on a budget, my guess is 440-1 heads fully ported with 2.25 intakes and stock rockers and an easy to live with cam that won't beat them to death would be my idea of what to do. You run super classes, so ultimate power is less important to you than being able to make a lot of passes between maintainance, right? That's was the point. That's a lot of money spent for 40HP increase. If I was buying new castings, new rocker gear, new manifold, etc, I would want more gain than that. But that's just me
[Re: Eric]
#2024760
03/05/16 12:00 AM
03/05/16 12:00 AM
Posts: 5,618 long island NY
Ari440
long island NY
I have indy sr,s and indy 440-1cnc 345s and now putting together a set of B1s
I spent lots of money to get to the next step
it all depends on you what you could afford
looking back at what I did should have bougth the B1s
1.39 9.85 - 137 mph
[Re: Eric]
#2024826
03/05/16 02:12 AM
03/05/16 02:12 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
The SR,s are the middle of the two other heads listed. Ported as your SR,s are, Id stay with them. Your car is light , and for the type of racing you do, is a fine head for your performance needs. My answer, no on the Victors and the Trick flows, keep what you have.
