Electric fuel pump #2023241
03/02/16 04:15 PM
03/02/16 04:15 PM
jeff500 Offline OP
jeff500  Offline OP
What electric f/p do you guys recomend for a very mild 360 magnum with a carb?
Re: Electric fuel pump [Re: jeff500] #2023283
03/02/16 04:56 PM
03/02/16 04:56 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
In tank Walbro 255? Overkill for a carb at that power level, but will be EFI ready, or ready for any upgrade you throw at it.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: Electric fuel pump [Re: jeff500] #2023329
03/02/16 06:08 PM
03/02/16 06:08 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I have had holley blue pumps give me great performance and reliability. One of my holley blue pumps was 18 years old when I decided to make it a spare and put a new one on. This was in a street car so it had lots of time on it.
68 Barracuda Formula S 340
Re: Electric fuel pump [Re: jeff500] #2023332
03/02/16 06:16 PM
03/02/16 06:16 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Carter P-46000-HP will work very well.
Nautilus Racing-
Re: Electric fuel pump [Re: jeff500] #2023363
03/02/16 07:01 PM
03/02/16 07:01 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
I know a fellow who's making near 800HP with a 500 inch Chubby and going 145MPH @ 3200 lb with 2 blue pumps. And it will go mid-1.20s in 60' if he gets after it. I keep telling him he needs to upgrade the fuel system and he asks "Why?". Not what I would be using, but it's hard to argue.
I would use one of those with a regulator before I used a red pump.
Re: Electric fuel pump [Re: Bad340fish] #2023652
03/03/16 03:18 AM
03/03/16 03:18 AM
MR_P_BODY Offline
MR_P_BODY  Offline
iagree ... I was running 2 of them in parallel and was
running 9.40s in a 395 ci.. even two of them might have been
over kill... but I wanted to be safe.. later I was running a
pair of 140 Holleys to run 8.90s and that was over kill...
but I run a return line on all my junk so I ran a return style
regulator... and the later system was with a 1.19 60'
wave
Re: Electric fuel pump [Re: jeff500] #2023670
03/03/16 04:42 AM
03/03/16 04:42 AM
jeff500 Offline OP
jeff500  Offline OP
Thanks guys.I was planning on running a reg but dont want to run a return line.
Re: Electric fuel pump [Re: Bad340fish] #2023686
03/03/16 09:46 AM
03/03/16 09:46 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
That's all my car has used. Have run 9.90's with 2 pumps on my 440. Might stay with them for the new combo, or maybe up it to black pumps.
[image][/image]
Re: Electric fuel pump [Re: jeff500] #2023741
03/03/16 12:18 PM
03/03/16 12:18 PM
East Coast
A/MP Offline
A/MP  Offline
East Coast
Holley Red through the factory mechanical pump. The factory pump supplies enough to handle 300HP. When you use it with the electrical pump you get all the fuel you need to 400HP And if the electric pump fails , it has enough suction to pull fuel from the tank and get you through the day. Also the factory pump acts as a regulator. Safe and simple.
