Recommend a harmonic balancer to me #202301
01/23/09 09:47 PM
01/23/09 09:47 PM
Benton, IL.
DaveRS23 Offline OP
Special needs idiot
DaveRS23  Offline OP
Special needs idiot
Benton, IL.
Street/strip 499" rb, 6,500 rpm max. I see SFI certified dampers priced anywhere from just over $100 to well over $400. I am so confused as to which one to get and why. Any enlightenment here would really be appreciated. Basically which one and why. Thanks!
Master, again and still
Re: Recommend a harmonic balancer to me [Re: DaveRS23] #202302
01/23/09 09:53 PM
01/23/09 09:53 PM
Connecticut
5126brl No more Offline
Connecticut
Do not cut cost here, Get A ATI super and forget it.
Mine is 23 years old and sent it back once for rebuild, cost $60.00 just to be safe
Re: Recommend a harmonic balancer to me [Re: 5126brl No more] #202303
01/23/09 10:16 PM
01/23/09 10:16 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
He wants to know WHY he should buy one over another. I'd like to know, too.
Re: Recommend a harmonic balancer to me [Re: StealthWedge67] #202304
01/23/09 10:36 PM
01/23/09 10:36 PM
Connecticut
Connecticut
I have heard of problems with the Fluid filled ones leaking . rattlers coming apart. So I would ask this question in the race forum to get more input from users of all styles.
Re: Recommend a harmonic balancer to me [Re: DaveRS23] #202305
01/23/09 10:53 PM
01/23/09 10:53 PM
MNobody Offline
MNobody  Offline
Still got the stock one on my warmed over 318, been spinnin up to 7000 for year's with no issues yet
Re: Recommend a harmonic balancer to me [Re: MNobody] #202306
01/24/09 12:59 AM
01/24/09 12:59 AM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
ATI
Re: Recommend a harmonic balancer to me [Re: DaveRS23] #202307
01/24/09 07:53 AM
01/24/09 07:53 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
We have Summits SFIs on 3 cars.No problems in 6 years.Rocky
Chrysler Firepower
Re: Recommend a harmonic balancer to me [Re: therocks] #202308
01/24/09 11:41 AM
01/24/09 11:41 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I've had a TCI Rattler on my RB for over 15 years now. Still in one piece.....that's about all I can tell you.
Re: Recommend a harmonic balancer to me [Re: J_BODY] #202309
01/24/09 11:55 AM
01/24/09 11:55 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I have a fluid damper I'd say buy a good one.
Talked with a guy at the track once and he said he had a CAT fail in the garage Lucky but his best friend's CAT failed on the way down the track and that was the end of a $12,000 motor???
I had a damper failour on a 542 but it was 100% my fault (took one from a crank that was oversize a bit so I honed the crap out of it and it fit perfect but cheaping out on my 542 I wanted to use it and it was not a tight fit and it rattled that block right apart after 80 runs. evn with a crank girdle and aluminum main caps it split the bolt holes in half and right up into ever cylinder)
I just bought a new Fluid Damp for my 452 last spring and when I get my new 542 done next spring it gets it's own new fluid damper.
Dam violins in the background!!! LOL!!!
Re: Recommend a harmonic balancer to me [Re: DaveRS23] #202310
01/24/09 01:29 PM
01/24/09 01:29 PM
Locomotion Offline
Locomotion  Offline
Summit sells Pioneer SFI balancers. I've run a small block version for years with no problems or bearing issues. They use the OEM rubber sandwich design which has worked very well and lasted for so many years. Now with better technology, they should be better.
Summit - Big Block Mopar SFI balancer
Re: Recommend a harmonic balancer to me [Re: Locomotion] #202311
01/24/09 01:38 PM
01/24/09 01:38 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
