Stage VI valve seals #2022542
03/01/16 01:14 PM
03/01/16 01:14 PM
bigfork mn
dragram440 Offline OP
bigfork mn
What are you running for valve seals with your stage VI heads? I figured since mine were off I would pull them apart and check them over and clean them up.
67' charger 499 RB 10.57 at 127
Re: Stage VI valve seals [Re: dragram440] #2022548
03/01/16 01:19 PM
03/01/16 01:19 PM
tboomer Online work
tboomer  Online Work
Roadhazzard...Greg can set you up. That's where I got mine.
Re: Stage VI valve seals [Re: tboomer] #2022671
03/01/16 04:43 PM
03/01/16 04:43 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Thanks tboomer thumbs
We have just about any size / combination you could want. If you need tech help just give us a ring!
Superformance Products catalog page
Re: Stage VI valve seals [Re: dragram440] #2022755
03/01/16 08:20 PM
03/01/16 08:20 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
If your heads are apart, get in with a small die grinder n cut channels to drain the oil away from the seal. Stage 6 heads have this stupid design where the oil is trying to drown the oil seal since the spring seat is recessed into the head.
Re: Stage VI valve seals [Re: dragram440] #2022970
03/02/16 01:51 AM
03/02/16 01:51 AM
bigfork mn
bigfork mn
I have done the drains in the spring pockets already.
