Proportioning Valve Mount #2022233
02/29/16 11:49 PM
02/29/16 11:49 PM
Minnesota
Bookemd Offline OP
Bookemd  Offline OP
Minnesota
Looking to see where you've all mounted your "prop valves"? I have a 68 Dart that I'm converting to discs. Also, do I need to use the stock distribution block as well? Pictures are appreciated.
Re: Proportioning Valve Mount [Re: Bookemd] #2022354
03/01/16 02:01 AM
03/01/16 02:01 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I mounted mine on a plate (bolted to the master mounting bolts) right under the master cylinder and used 6" long hard lines between the master and the valve. Its pretty easy to get at to adjust with it there. Sorry, no pictures. Gene
Re: Proportioning Valve Mount [Re: poorboy] #2022409
03/01/16 04:29 AM
03/01/16 04:29 AM
None
71rm23 Offline
71rm23  Offline
None
Under M/C
Re: Proportioning Valve Mount [Re: Bookemd] #2022415
03/01/16 05:54 AM
03/01/16 05:54 AM
Bloomingdale Il
Sedanman Offline
Sedanman  Offline
Bloomingdale Il
The disc prop valve replaces the drum one and is mounted to the lower DS frame rail. Is yours factory or aftermarket? If you are using the 73-6 style prop and disc brakes you may have to change the line that passes across the firewall. I just bought a kit from finelines for a 73-6 duster with disc brakes. If your doing the same thing just get the kit for a 73-6 Dart with disc brakes.
Re: Proportioning Valve Mount [Re: Sedanman] #2022744
03/01/16 07:51 PM
03/01/16 07:51 PM
Minnesota
Bookemd Offline OP
Bookemd  Offline OP
Minnesota
Thanks! I'm using Inline Tube's adjustable proportion valve. Do I need to use the stock distribution block as well?
Re: Proportioning Valve Mount [Re: Bookemd] #2022968
03/02/16 01:49 AM
03/02/16 01:49 AM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
yes
5549 post on old board
Re: Proportioning Valve Mount [Re: 05dakota] #2023016
03/02/16 04:42 AM
03/02/16 04:42 AM
Minnesota
Bookemd Offline OP
Bookemd  Offline OP
Minnesota
Thanks for help Got it installed tonight
