Battery Charging Question #202130
01/23/09 06:06 PM
01/23/09 06:06 PM
MNobody Offline OP
MNobody  Offline OP
I put a Marine battery in the Dart a year or two ago because it was almost new and i don't use the boat anymore. i have the battery charger on it to top it off because it's been sitting for several months, should i use the regular or deep cycle setting on the battery charger? Thanks.
Re: Battery Charging Question [Re: MNobody] #202131
01/23/09 06:29 PM
01/23/09 06:29 PM
MoreParts Offline
MoreParts  Offline
I use deep cycle on my cars that sit for long periods. The gel batteries have their own setting.
Re: Battery Charging Question [Re: MoreParts] #202132
01/23/09 06:48 PM
01/23/09 06:48 PM
MNobody Offline OP
MNobody  Offline OP
Hope i didn't damage it...I had it charging on automatic regular all day because i forgot it was a Marine battery. Thanks.
Re: Battery Charging Question [Re: MoreParts] #202133
01/23/09 08:30 PM
01/23/09 08:30 PM
MNobody Offline OP
MNobody  Offline OP
whoa i missed that the first time, deep cycle batteries have gel in them instead of acid?
Re: Battery Charging Question [Re: MNobody] #202134
01/24/09 12:47 AM
01/24/09 12:47 AM
Arlington, Texas
earlybee Offline
earlybee  Offline
Arlington, Texas
Use a FLOAT charger.
Re: Battery Charging Question [Re: earlybee] #202135
01/24/09 10:09 AM
01/24/09 10:09 AM
MNobody Offline OP
MNobody  Offline OP
You mean one of these?
Re: Battery Charging Question [Re: MNobody] #202136
01/24/09 01:04 PM
01/24/09 01:04 PM
Arlington, Texas
earlybee Offline
earlybee  Offline
Arlington, Texas
I,m using 3 of those right now. One is 8 years old and still works fine.
