Re: Finally got my 8 sec slip
[Re: WHITEDART]
#2021965
02/29/16 05:20 PM
02/29/16 05:20 PM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
Awesome! Congrats on the 8 sec pass!!
[Re: WHITEDART]
#2022058
02/29/16 08:19 PM
02/29/16 08:19 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
3080 lb power glide with the set of Brett Miller baby 8s That is flying, Congrats. :-} But what is a set of Brett Miller baby 8,s Also agree that the DA isn't great compared to around here. Witch makes your run even more impressive. my W8 were an odd ball set. I was not 100% on what they were originally built 4.but when I got them they were set up with a fresh set of titanium 2.15 intake valves.which is about the smallest that I have heard of most commonly they would use 2.18---- 2.25 Brett has a really big port that goes into these heads. But it would have require me to buy another set of intake valves which I didn't want to do at the time. What I will tell you Bretts cylinder heads make killer horsepower and carry really well and you don't have to turn them to the moon.....thanks again Brett Correction. Many W8's made big hp. Patterson, Eatman, Davis all who used CFE. Brett's heads make torque. It takes torque to make hp. With a given torque # the higher the rpm you can hold most of it the more hp you make. When an engine makes big torque leading to hp at a lower rpm it runs better et. Example two cars. One makes 900hp at 9k with only making a tic over 600ft. Lbs.at 7,600. Another car same converter weight everything that makes 10 lbs more torque and nets the same hp at 8,500 will run faster. You need torque or you will be in a terrible search to find that perfect converter. For most of us on a budget unobtainable. You find some 60ft. and she'll fly. Your rear half is a challenge. My lack of torque wazeka mine.
[Re: Street Monkies]
#2022256
03/01/16 12:17 AM
03/01/16 12:17 AM
Posts: 1,784 PA
W5DART66
PA
Bigger isn't always better. For this particular combination maybe the way the heads are set up is the best match, and will work better than the bigger valves/port. BIGGER is better. This is not a small block it's 440ci It needs a 2.200+ intake valve and 3.3" min cross section. And it don't have that yet....
[Re: W5DART66]
#2022258
03/01/16 12:20 AM
03/01/16 12:20 AM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
Bigger isn't always better. For this particular combination maybe the way the heads are set up is the best match, and will work better than the bigger valves/port. BIGGER is better. This is not a small block it's 440ci It needs a 2.200+ intake valve and 3.3" min cross section. And it don't have that yet.... Yet!
Brian Hafliger
[Re: W5DART66]
#2022267
03/01/16 12:26 AM
03/01/16 12:26 AM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
Bigger isn't always better. For this particular combination maybe the way the heads are set up is the best match, and will work better than the bigger valves/port. BIGGER is better. This is not a small block it's 440ci It needs a 2.200+ intake valve and 3.3" min cross section. And it don't have that yet.... Patience Brett you and I both know at some point BIG will find it's way on his car, just a matter of time and money
"Just a Bracket car dressed up like a streetcar"
[Re: Just-a-dart]
#2022541
03/01/16 01:11 PM
03/01/16 01:11 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Yes I can see 15 to 1.and big ports and a big intake in my future. And some q16
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: WHITEDART]
#2023370
03/02/16 07:13 PM
03/02/16 07:13 PM
Posts: 3,456 Out West
408strokerdart
Out West
Yes I can see 15 to 1.and big ports and a big intake in my future. And some q16 Yes.....and that will equal 8.60's. Just ask me how I know. LOL. Congrats on the nice runs. Glad it's performing well for you.
