Makes me want to ditch my Dana 60.....Wow new Alum 9" Center #2020803
02/27/16 04:14 PM
02/27/16 04:14 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
Re: Makes me want to ditch my Dana 60.....Wow new Alum 9" Center [Re: Dragula] #2020826
02/27/16 05:02 PM
02/27/16 05:02 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
The bolt on tubes scare me.
Re: Makes me want to ditch my Dana 60.....Wow new Alum 9" Center [Re: tubtar] #2020841
02/27/16 05:49 PM
02/27/16 05:49 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
I would assume the the tube inserts into the housing 3-4" and the flange bolts just hold it in there. Not much choice when using steel tubes on an aluminum housing.
kevin
Re: Makes me want to ditch my Dana 60.....Wow new Alum 9" Center [Re: Twostick] #2020845
02/27/16 06:00 PM
02/27/16 06:00 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
kevin
Curries Aluminum dana 60 bolts in as well, like you said there really isn't any other choice. Currie just did theirs a bit different.
Re: Makes me want to ditch my Dana 60.....Wow new Alum 9" Center [Re: Dragula] #2020847
02/27/16 06:03 PM
02/27/16 06:03 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Mark Williams "Modular" rear ends have had bolt on tubes since they were designed and are the rear of choice under the fastest doorslammers on the planet.
For a race car, provisions would have to be made to install some type back brace
Re: Makes me want to ditch my Dana 60.....Wow new Alum 9" Center [Re: Dragula] #2020860
02/27/16 06:41 PM
02/27/16 06:41 PM
gregsdart Offline
gregsdart  Offline
Any idea of how much weight this saves over a Dana of the same width?
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
Re: Makes me want to ditch my Dana 60.....Wow new Alum 9" Center [Re: Dragula] #2020941
02/27/16 09:47 PM
02/27/16 09:47 PM
Here
jcc Offline
jcc  Offline
Here
The ad list built for any rear, Chrysler, etc, does that mean 8.75"?
With axles for $995?
And is it billet, or a high pressure alum casting or what?
Looks neat, and at a price i think it might catch, better get them quick before demand catches up. biggrin
" All sorts of things can happen when you are open to new Ideas" Inventor of Kevlar
