Re: Tunnel ram intake
[Re: Wedgeman]
#2020751
02/27/16 02:44 PM
02/27/16 02:44 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I ran one for a while.. the vac secondary carbs never worked like I wanted.. I tried everything to get them to work right..I went with a single 4bbl carb and each one that was larger was quicker and faster
[Re: Wedgeman]
#2020760
02/27/16 03:06 PM
02/27/16 03:06 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Never used them on a small block. Have run2x4 tunnel ram on big blocks. Really like them. Carb selection is critical. No vacuum secondaries. I would use Holley 450 TR carbs for street motor, 660 center squirters for street/strip or better.
[image][/image]
[Re: Wedgeman]
#2020978
02/27/16 10:39 PM
02/27/16 10:39 PM
Posts: 1,361 Wild West
M_D
Wild West
Tunnel rams work great if you have a solid engine and chassis combination. In my opinion the general idea that they are "exotic" and not "streetable" is overstated. Other than the obvious issues such as height, extra parts ($$$) and weight I can't think of significant drawbacks. If you know how to tune one carb well, you just have an extra one to tune. If you can't tune well and your carbs are not right, then you will likely not be happy.
[Re: mopar dave]
#2021144
02/28/16 06:07 AM
02/28/16 06:07 AM
Posts: 4,457 Washington
madscientist
Washington
I'm planning a t ram set up for my 410 race gas motor. Won't be ready this season. Still need lincage and fuel lines. Just got the carbs two 750 ultras per Mark and some others recommendations. I didn't realize you were using W2 stuff. That is my favorite TR. I have used several and they work every time.
[Re: Wedgeman]
#2021179
02/28/16 11:23 AM
02/28/16 11:23 AM
Posts: 10,013 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Some have reported as much as 40 hp gain on a 572 motor with 572-13 heads. I am betting if you figure a possible gain of four percent, you wouldn't be far off, given the motor operates in the right rpm range with both single and TR set ups close to optimum. I saw a good gain on a 440 stroker by going with a tunnelram, picked up another tenth and a half after install by opening up the runners a bunch.
[Re: Wedgeman]
#2021865
02/29/16 02:23 PM
02/29/16 02:23 PM
Posts: 20,655 in a cattle trailer down by th...
Guitar Jones
My small block picked up .4 with a TR and two 750's over a single 950 with no other changes. The driveability and throttle response was also greatly improved and I spent a lot of time on that single 4 combo.
