1968 gtx dash finish #202036
01/23/09 03:06 PM
01/23/09 03:06 PM
Missouri
P
petty43 Offline OP
petty43  Offline OP
P
Missouri
What type of finish is the original dash on a 68 gtx or roadrunner?
Flat, Semi gloss, ?
1968 Satellite RR Copy Cat My Fleet
Re: 1968 gtx dash finish [Re: petty43] #202037
01/23/09 04:01 PM
01/23/09 04:01 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Suede Texture...
Re: 1968 gtx dash finish [Re: 1_WILD_RT] #202038
01/23/09 04:20 PM
01/23/09 04:20 PM
Missouri
P
petty43 Offline OP
petty43  Offline OP
P
Missouri
Thanks!
Was the door tops the same finish or smooth?
Re: 1968 gtx dash finish [Re: petty43] #202039
01/23/09 04:38 PM
01/23/09 04:38 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Smooth shiney paint
Re: 1968 gtx dash finish [Re: 1_WILD_RT] #202040
01/23/09 06:00 PM
01/23/09 06:00 PM
Missouri
P
petty43 Offline OP
petty43  Offline OP
P
Missouri
Thanks again. I found the ash tray with the original dark green finish and it is flat and slightly textured. The paint shop couldn't replicate the texture but that's ok with me.
Re: 1968 gtx dash finish [Re: petty43] #202041
01/24/09 11:20 AM
01/24/09 11:20 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
my 68 RR ashtray is padded, is a GTX different?
Re: 1968 gtx dash finish [Re: ademon] #202042
01/24/09 02:34 PM
01/24/09 02:34 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Early 68 had a padded slider
Late 68-70 had a metal tilt out
Re: 1968 gtx dash finish [Re: 1_WILD_RT] #202043
01/24/09 04:18 PM
01/24/09 04:18 PM
car48nut Offline
car48nut  Offline
Late 68's were ateel painted and they pulled out. The early ones slid down and were padded.
Re: 1968 gtx dash finish [Re: car48nut] #202044
01/24/09 06:53 PM
01/24/09 06:53 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
The pad doesn't cover the whole ashtray; the lower part is sueded finish to match the dash. Ashtrays of the same type (as in folding or sliding) are the same whether GTX or RR or Satellite.
Dash and steering column are same color & texture. There are some recent threads on this you can look up. Correct texture is something like 600-grit sandpaper. Lacquer applies best. Defroster grilles are not painted. 1 pint pre-reduced/thinned is more than enough. Practice to get the right finish.
Re: 1968 gtx dash finish [Re: 1_WILD_RT] #202045
01/24/09 08:44 PM
01/24/09 08:44 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
Padded ash trays were found in all b bodies.
We had a padded ash tray thread going here not long ago. What do you consider early? My car was as posted in that thread as the latest car to have a pad 5/21/68 and have seen a good # up to early May. Seems they were used till gone is the only thing I can come up with.
Re: 1968 gtx dash finish [Re: rrunner] #202046
01/24/09 08:55 PM
01/24/09 08:55 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
And your interior color is what....They changed the design...There is no set date, when the stock of the first version ran out they started using the revised design...
Re: 1968 gtx dash finish [Re: 1_WILD_RT] #202047
01/24/09 10:17 PM
01/24/09 10:17 PM
Missouri
P
petty43 Offline OP
petty43  Offline OP
P
Missouri
That means the cool green ones went real quick!
Re: 1968 gtx dash finish [Re: petty43] #202048
01/24/09 10:52 PM
01/24/09 10:52 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Yeah I think green ran out early, black was first & maroon lasted the longest...
Re: 1968 gtx dash finish [Re: 1_WILD_RT] #202049
01/24/09 10:55 PM
01/24/09 10:55 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
My dash is red/maroone. All I'm saying is it wasn't a early thing. If there was a change it was as I said, a run till thety are gone, that's not limited to early. I have been trying to pin point a time when they changed with no luck. I have had cars with pull outs with earlier dates than cars with sliders. I am starting to think the sliders were a 68 run, but due to problems with the pads coming apart, like they do, many may have been changed and possibly early on. I have talked with many people on this and posted here and still come up without a 4 sure answer. I know 110% 4 sure mine is org. to my car.
Re: 1968 gtx dash finish [Re: 1_WILD_RT] #202050
01/24/09 11:06 PM
01/24/09 11:06 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
I have seen red/maroone earlier than mine with pull out from the same plant Saw a 4/8/68 GTX today with a black slider
I sure Mike, A12, could post a link to that slider post if he chimes in.
