01 CHEROKEE 2WD -CONVERTER SOLENOID CODE
#2016524
02/21/16 11:12 AM
02/21/16 11:12 AM
crabman173
crabman173
Hey guys--any Jeep techs here--wife LOVES her 01 Grand Cherokee 4.7 two wheel drive--just turned 200K then it throws code for converter lock up solenoid--Jeep runs great--trans acts just fine What am I looking at here to get it fixed?? Can I just grab another valve body from Pick a Part or is trans doomed? How long will it go? Thanks
Re: 01 CHEROKEE 2WD -CONVERTER SOLENOID CODE
[Re: ]
#2016528
02/21/16 11:30 AM
02/21/16 11:30 AM
Guitar Jones
[Re: ]
#2016534
02/21/16 11:47 AM
02/21/16 11:47 AM
crabman173
crabman173
Think it is 45 RFE? Guessing I am in for solenoid pack replacement Thing acts just fine but I erased code and it came back day or so later Thanks!!
[Re: ]
#2017394
02/22/16 02:43 PM
02/22/16 02:43 PM
Guitar Jones
Replace the solenoid pack and the filters. Make sure you get a Mopar filter for that little screw on one.
[Re: ]
#2017494
02/22/16 04:58 PM
02/22/16 04:58 PM
crabman173
crabman173
[Re: ]
#2017658
02/22/16 09:21 PM
02/22/16 09:21 PM
crabman173
crabman173
Guitar Jones Replaced it with Mopar new solonoid pack--replaced rooster comb with new one for white socket pack--runs like a dream--shifts way better than it did --no real issues before that light came on and even better now but--throwing different code 0700 now--maybe I was low fluid before I got her all topped off?? Do I just need may pal with scanner to reset all codes? Can I reset/ erase here at home--tried battery cable off--soon as I hook it up getting that 0700 Code before was different for converter lock up pressure or some such can't remember now--Hey she runs great! Whats next and BTW THANKS!!!!!!!!!!!!!!!
[Re: ]
#2017989
02/23/16 12:43 PM
02/23/16 12:43 PM
crabman173
crabman173
Good news! Shifting like a dream now and...light went out by itself--all happy now I learned when replacing a "black plug" solenoid pack that you will get upgraded "white plug" unit that requires an updated rooster comb also--it was easy fix ( except the mess) and fixed it! Thanks for the input
[Re: ]
#2020117
02/26/16 12:55 PM
02/26/16 12:55 PM
Guitar Jones
Glad you got it fixed. Sorry I didn't see your post before now.
