01 CHEROKEE 2WD -CONVERTER SOLENOID CODE #2016524
02/21/16 11:12 AM
02/21/16 11:12 AM
crabman173 OP
crabman173 OP
Hey guys--any Jeep techs here--wife LOVES her 01 Grand Cherokee 4.7 two wheel drive--just turned 200K then it throws code for converter lock up solenoid--Jeep runs great--trans acts just fine
What am I looking at here to get it fixed?? Can I just grab another valve body from Pick a Part or is trans doomed? How long will it go? Thanks
Re: 01 CHEROKEE 2WD -CONVERTER SOLENOID CODE [Re: ] #2016528
02/21/16 11:30 AM
02/21/16 11:30 AM
Guitar Jones Offline
What Trans is in it?
Re: 01 CHEROKEE 2WD -CONVERTER SOLENOID CODE [Re: ] #2016534
02/21/16 11:47 AM
02/21/16 11:47 AM
crabman173 OP
crabman173 OP
Think it is 45 RFE? Guessing I am in for solenoid pack replacement
Thing acts just fine but I erased code and it came back day or so later
Thanks!!
Re: 01 CHEROKEE 2WD -CONVERTER SOLENOID CODE [Re: ] #2016560
02/21/16 01:01 PM
02/21/16 01:01 PM
ky.
K
kenworth_goose Offline
K
ky.
Drop the pan and replace all of the electronics inside the trans.
Re: 01 CHEROKEE 2WD -CONVERTER SOLENOID CODE [Re: ] #2017394
02/22/16 02:43 PM
02/22/16 02:43 PM
Replace the solenoid pack and the filters. Make sure you get a Mopar filter for that little screw on one.
Re: 01 CHEROKEE 2WD -CONVERTER SOLENOID CODE [Re: ] #2017494
02/22/16 04:58 PM
02/22/16 04:58 PM
crabman173 OP
crabman173 OP
Thanks!
Re: 01 CHEROKEE 2WD -CONVERTER SOLENOID CODE [Re: ] #2017658
02/22/16 09:21 PM
02/22/16 09:21 PM
crabman173 OP
crabman173 OP
Guitar Jones
Replaced it with Mopar new solonoid pack--replaced rooster comb with new one for white socket pack--runs like a dream--shifts way better than it did --no real issues before that light came on and even better now but--throwing different code 0700 now--maybe I was low fluid before I got her all topped off?? Do I just need may pal with scanner to reset all codes? Can I reset/ erase here at home--tried battery cable off--soon as I hook it up getting that 0700 Code before was different for converter lock up pressure or some such can't remember now--Hey she runs great! Whats next and BTW THANKS!!!!!!!!!!!!!!!
Re: 01 CHEROKEE 2WD -CONVERTER SOLENOID CODE [Re: ] #2017989
02/23/16 12:43 PM
02/23/16 12:43 PM
crabman173 OP
crabman173 OP
Good news!
Shifting like a dream now and...light went out by itself--all happy now
I learned when replacing a "black plug" solenoid pack that you will get upgraded "white plug" unit that requires an updated rooster comb also--it was easy fix ( except the mess) and fixed it!
Thanks for the input
Re: 01 CHEROKEE 2WD -CONVERTER SOLENOID CODE [Re: ] #2020117
02/26/16 12:55 PM
02/26/16 12:55 PM
Glad you got it fixed. Sorry I didn't see your post before now.
