Factory cassette player/recorder #2019053
02/24/16 09:05 PM
02/24/16 09:05 PM
Harriman NY
71GTX471 Offline OP
71GTX471  Offline OP
Harriman NY
Need some help compiling my cassette player/recorder parts list for accuracy,while going over the list today I realized that Chrysler doesn't show a different part# for B/E body Auto & 4spd. pedestal floor mount bracket in either there 71 or 72 parts catalog & there is defiantly 2 types,they only show B/E-body #3501170 & C-body #3501171.
I have the complete 4spd. setup & only the Auto pedestal,the 4spd.bracket does not fit inside the Auto pedestal its wider along with also being longer on the r/side by about an inch whereas the Auto one is equal length on each side.
I'm thinking that maybe the C-body bracket is also used as the B/E-body Auto bracket its possible that the top of the trans tunnel is similar in shape as the B/E-body therefore the bracket is possibly the same part#.
Does anyone have a known B/E bracket & a known C-body bracket that they can check the stamped part# on & let me know,once I have the facts straight Ill post the parts list for everyone to have.Also any known A-body bracket part#.
Tnx Mike
Re: Factory cassette player/recorder [Re: 71GTX471] #2019224
02/25/16 01:36 AM
02/25/16 01:36 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
4 speed one with bracket on right, auto and bracket on left
Re: Factory cassette player/recorder [Re: 71GTX471] #2019396
02/25/16 12:15 PM
02/25/16 12:15 PM
Franklin Square, NY
CUDAAR Offline
CUDAAR  Offline
Franklin Square, NY
I received this list from a member here named Turnie a couple of years ago. He got it from another Mopar site. I can't vouch for accuracy, but I hope it helps. -Lou
Cassette Part Numbers
cassette recorder was offered only 1971-73
3501045 recorder 3501512 in the 73 book
3501077 primary knob
3501078 secondary
3501538 mode selector (1972 book)
4129GX9 upper shroud all Body styles
4124GX9 lower shroud all Body styles
4126GX9 pedestal shroud A body only
4130GX9 pedestal shroud /console E,B Bodies only
4127GX9 w/o console same as above
4125GX9 pedestal shroud C body only
3501046 microphone 1971-72 3501534 1973
3501151 demonstration cassette
3513143 wiring A body only
3501106 wiring unit to radio 44 inches all Bodies
3501107 wiring unit to radio 9 inches E,B Bodies only
3501501 Am/FM multiplex radio E Body used / cassette 1972-73 book
3501502 same as above C body 1972-73
3501053 AM radio 1971 only A Body
all above from the 71 part book dated January 1972 unless noted otherwise
The plastic shrouds were only serviced in black as replacements GX9 is black G is the year and X is black,9 is how dark it is.
The microphone had one change as the cord was either coiled or not.
These are the only things related to the recorder I can find.
NOTE: Except for the 1971 book which shows a DUAL AUDIO/INPUT 3501053 radio
there is NO mention of any radios for the 72-73 A Body models used /cassettes in
the part book. Also the shrouds for the A bodies only show up in the 1971 book. So
according to the part books the recorder was only available in the 1971 A bodies.
I had years ago the microphones /coiled cables and some of the shrouds that I ordered when they were available. Long gone now!
Re: Factory cassette player/recorder [Re: 71GTX471] #2019411
02/25/16 12:43 PM
02/25/16 12:43 PM
Harriman NY
71GTX471 Offline OP
71GTX471  Offline OP
Harriman NY
mccannix do you have those pedestals in your possession if so what's the part# stamped on the Auto bracket.
Re: Factory cassette player/recorder [Re: 71GTX471] #2140552
08/25/16 01:29 PM
08/25/16 01:29 PM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
My 71 RR with a floor mounted cassette, auto column, has the original holes in the floor and it looks like it needs the offset one. Is it possible that the one on the right is for all B/E bodies floor mounting? I have two on the left and both cross to a C body floor mount PN.
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
Re: Factory cassette player/recorder [Re: 71GTX471] #2140621
08/25/16 02:58 PM
08/25/16 02:58 PM
Tucson, AZ
cruzin Offline
cruzin  Offline
Tucson, AZ
I have the following radio and cassette player/recorder acquired years ago. After see your post, decided to dig it out.
Originally I was told it's for a C-body. However, I just entered the p/n (3501080) found on the cassette base cover and it appears to be for an A-body. I can't locate a p/n on the radio but it's cabled correctly for the player/recorder so it appears to be the one that goes with it.
Perhaps one of you who's more up on these radio-cassette P/R can help me out with exactly what this unit is.
Re: Factory cassette player/recorder [Re: cruzin] #2140638
08/25/16 03:32 PM
08/25/16 03:32 PM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
Found a picture of an original car by the looks of it. Offset mount on this one too.
1959 Bugeye Sprite
1971 MG Midget
Re: Factory cassette player/recorder [Re: 71GTX471] #2140951
08/25/16 10:56 PM
08/25/16 10:56 PM
Harriman NY
71GTX471 Offline OP
71GTX471  Offline OP
Harriman NY
SPB I saw that & plus what you said about needing the slanted type is starting too make me think I may have it reversed auto vs stk but then what MCNX is showing has me all fouled up,if I could get in my damm car I would go & ck.myself.
Re: Factory cassette player/recorder [Re: 71GTX471] #2141118
08/26/16 02:24 AM
08/26/16 02:24 AM
Kennewick, Wa.
71vert340 Offline
71vert340  Offline
Kennewick, Wa.
Here's the original cassette player in my 71 Challenger 4 speed. Got car in 1972.
Re: Factory cassette player/recorder [Re: 71GTX471] #2279098
03/30/17 09:01 PM
03/30/17 09:01 PM
Virginia Beach, VA
Rick_Barracuda Offline
Virginia Beach, VA
Is this thread still active? I need some info on a cassette player.
Rick
1964 Plymouth Barracuda
1965 Plymouth Valiant
www.ricksradioconversions.com
Re: Factory cassette player/recorder [Re: 71GTX471] #2279401
03/31/17 09:52 AM
03/31/17 09:52 AM
Harriman NY
71GTX471 Offline OP
71GTX471  Offline OP
Harriman NY
What kind of info Rick,I just received a automatic base bracket that I was looking for & main mounting with a mint B5 lower housing $50 free shipping.
Re: Factory cassette player/recorder [Re: CUDAAR] #2279845
03/31/17 09:16 PM
03/31/17 09:16 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Actually 74s too
Re: Factory cassette player/recorder [Re: 71GTX471] #2310122
05/24/17 12:34 AM
05/24/17 12:34 AM
Virginia Beach, VA
Virginia Beach, VA
I am looking for the owners manual. I put new belts in it and got it working pretty good.
Rick
Re: Factory cassette player/recorder [Re: 71GTX471] #2310205
05/24/17 09:16 AM
05/24/17 09:16 AM
Harriman NY
71GTX471 Offline OP
71GTX471  Offline OP
Harriman NY
Rick where did you get belts & what's the part# for them.
Re: Factory cassette player/recorder [Re: 71GTX471] #2310348
05/24/17 01:43 PM
05/24/17 01:43 PM
Southwest USA
71muffin Offline
71muffin  Offline
Southwest USA
I may be wrong but isn't the one on the right for a no console set up and the other one is for a console mount. Shouldn't make any difference if the car is an e body or b body.
Does anyone know who repairs these units?
Re: Factory cassette player/recorder [Re: 71muffin] #2310387
05/24/17 02:59 PM
05/24/17 02:59 PM
None
71rm23 Offline
71rm23  Offline
None
Yes, there is a difference between having a console and not. The mounts are different as posted in the pictures. Doesn't make a difference between E or B body neither. If my memory serves me correctly, I think Chrysler mad 137 with this option.
No, no one rebuilds these. There used to be but parts are so scarce anymore. I did have a site that you can order the belts for these but can't find it. I'm sure they're on my other computer that died on me and can't get it. There are 2 different lengths of belts for these
Re: Factory cassette player/recorder [Re: 71rm23] #2310455
05/24/17 05:10 PM
05/24/17 05:10 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
When it comes to console mount verses pedestal, here are the different plastic shroud bases.
First picture is the plastic base for console mount...notice the bottom lip about 1/2 inch around and the corresponding bracketry that mounts cassette to console.
Second picture shows the plastic base for floor mount..virtually same plastic base but without the 1/2 inch lip.
The console cassette base with the lip is the hardest item to find in my opinion.
Third picture shows the two together.
Re: Factory cassette player/recorder [Re: 71GTX471] #2310578
05/24/17 09:11 PM
05/24/17 09:11 PM
Harriman NY
71GTX471 Offline OP
71GTX471  Offline OP
Harriman NY
Just bought a cassette player only with the correct knobs of Ebag $150.
Re: Factory cassette player/recorder [Re: 71GTX471] #2315741
06/03/17 11:04 PM
06/03/17 11:04 PM
Virginia Beach, VA
Virginia Beach, VA
do
eBay
SONY 3-454-043/3-336-267-01/359998300/ 3-462-132-00 /3-507-088
GES10.7 SQUARE BELT
ALPINE 7100/7114/7123/7217 SCX8.6 SQUARE BELT
Amecbol this is the seller name. They work good man! Sorry took so long to reply
Rick
Re: Factory cassette player/recorder [Re: 71GTX471] #2315742
06/03/17 11:05 PM
06/03/17 11:05 PM
Virginia Beach, VA
Virginia Beach, VA
So far I am 3 for 3 in fixing restoring these.
Rick
