wheel question 15x8 backspacing and tire size 70' b-body #2018494
02/24/16 12:39 AM
02/24/16 12:39 AM
North EAST
seventy Offline OP
seventy  Offline OP
North EAST
So I am ordering 15x7 fronts and 15x8 steel rear repro wheels for a 70' charger, I have a couple questions, you guys may know the answers to and save me some trouble, thanks in advance..
First, I have the choice of 4" or 4.5" back spacing for the 15x8 (5x4.5) rears?
Next what size tires fit comfortably and look good in the b-body wells? Pics and size info would be great if you could share your experiences, thanks again..
Re: wheel question 15x8 backspacing and tire size 70' b-body [Re: seventy] #2018509
02/24/16 01:08 AM
02/24/16 01:08 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
On and 8" wheel 3-1/2" backspacing is nice ... so go with the 4". 4-1/2 will set the whole combo further into the well and looks a bit goofy although 1/2" isn't all that noticeable!
Re: wheel question 15x8 backspacing and tire size 70' b-body [Re: seventy] #2018539
02/24/16 01:28 AM
02/24/16 01:28 AM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
The wheel wells are huge, I run 10s with 3.75 BS I think, I would prefer 4.25 so 4 on an 8 would look good I think. 275 60 15s would be a good size but again, I like a wider tire. I run N50s on the 68 and old L60 sticky Mickeys on 10s on the 69.
Careful, your character's showing!
Re: wheel question 15x8 backspacing and tire size 70' b-body [Re: seventy] #2018547
02/24/16 01:36 AM
02/24/16 01:36 AM
mopar346 Offline
mopar346  Offline
69
Re: wheel question 15x8 backspacing and tire size 70' b-body [Re: mopar346] #2018698
02/24/16 12:20 PM
02/24/16 12:20 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Back in the day. 15 x 8 w/3-1/2 BS. L50-15 tires.
Unlike the Dodges in the previous post, these fit without jacking the back up, no rubbing through suspension travel.
Couldn't afford the fronts yet!
Re: wheel question 15x8 backspacing and tire size 70' b-body [Re: seventy] #2018711
02/24/16 12:41 PM
02/24/16 12:41 PM
mopar346 Offline
mopar346  Offline
Neither of those cars are jack up by artificial means, both have the orignal 440/hemi suspension although the 68 has an extra leaf added to the stack back in the day. Neither scrubb even in off camber situations. The back space is the key, one of the reasons I said I would prefer 4.25 over the 3.75s. The rake is due to not having enough height in either the tortion bars and I probably give up an inch just in the front tire height compared to the rear.
Re: wheel question 15x8 backspacing and tire size 70' b-body [Re: mopar346] #2018998
02/24/16 07:54 PM
02/24/16 07:54 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
I'd do the 4.5 with an 8" wheel
Mine are 5.5 back on a 9.5 wheel. Just in 17's...
...FAFO...
Re: wheel question 15x8 backspacing and tire size 70' b-body [Re: skicker] #2019680
02/25/16 08:02 PM
02/25/16 08:02 PM
Harleysville, PA USA
Tommy D Offline
Tommy D  Offline
8" wheel with 4.5" back-spacing works great on Plymouth b-bodies. Be careful as Dodge (Super Bees for sure) have a slightly larger wheel well. I can run 275-60-15 tires with no rubbing issues at all. I have photos, but can't seem to post them. I can fit an entire finger between the back of the tire and the leaf spring, as well as on the outter lip of the fender. This is for a '69 Road Runner. I'm guessing the '70 is similar, if not exact.
As an fyi...lots of the stock eliminator guys and fast street racers go with a 15 x 10 x 5.5" back-spacing. They use the same tires. It gives a different contact patch, and an entirely different look.
Re: wheel question 15x8 backspacing and tire size 70' b-body [Re: seventy] #2019700
02/25/16 08:20 PM
02/25/16 08:20 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
I am with TommyD . With my 68 Satellite I have 15x8 with 4.5"BS , fit fine with 275/60R15 . Though I now use 255/70R15 on the street . With 8" wide 4"BS and 275's with 4 guys in car I had to roll fender lip due to rubbing . I also have 15x8.5 with 3 7/8BS , with MT 28x10.5 pro bracket radials it gets a very slight rub up in the wheel well outside , this is racing .
10" need 5.5"BS , a couple friends have this on their Plymouths with 295/50R15 , but there is sometimes a slight rub mostly inner wheel well .
The Coronet does fit a 30" tyre easier .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: wheel question 15x8 backspacing and tire size 70' b-body [Re: tex013] #2019807
02/25/16 10:08 PM
02/25/16 10:08 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
8 inch, 4.5 bp and 275/60 on my 68 Sat
Re: wheel question 15x8 backspacing and tire size 70' b-body [Re: skicker] #2019882
02/25/16 11:58 PM
02/25/16 11:58 PM
mopar346 Offline
mopar346  Offline
Are your springs moved in any? I have a set of 5.25 BS 10s that I cant use on anything cause it hits the springs when running the lugs down. They do have a wide cross section tire on them though.
Re: wheel question 15x8 backspacing and tire size 70' b-body [Re: mopar346] #2020065
02/26/16 11:33 AM
02/26/16 11:33 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
They're not moved in at all.
SS springs moved back 3/4" with 1 1/2" lowering blocks. The tread is 9.5 and I think the section width is about 12".
...FAFO...
Re: wheel question 15x8 backspacing and tire size 70' b-body [Re: seventy] #2020521
02/27/16 12:32 AM
02/27/16 12:32 AM
mopar346 Offline
mopar346  Offline
Gotcha the cross section on the ones I have with the 5.25 back space is 13 and change.
