Re: wheel question 15x8 backspacing and tire size 70' b-body
[Re: seventy]
#2018539
02/24/16 01:28 AM
02/24/16 01:28 AM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
The wheel wells are huge, I run 10s with 3.75 BS I think, I would prefer 4.25 so 4 on an 8 would look good I think. 275 60 15s would be a good size but again, I like a wider tire. I run N50s on the 68 and old L60 sticky Mickeys on 10s on the 69.
Careful, your character's showing!
[Re: seventy]
#2018711
02/24/16 12:41 PM
02/24/16 12:41 PM
mopar346
Neither of those cars are jack up by artificial means, both have the orignal 440/hemi suspension although the 68 has an extra leaf added to the stack back in the day. Neither scrubb even in off camber situations. The back space is the key, one of the reasons I said I would prefer 4.25 over the 3.75s. The rake is due to not having enough height in either the tortion bars and I probably give up an inch just in the front tire height compared to the rear.
[Re: mopar346]
#2018998
02/24/16 07:54 PM
02/24/16 07:54 PM
Posts: 5,106 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
I'd do the 4.5 with an 8" wheel Mine are 5.5 back on a 9.5 wheel. Just in 17's...
...FAFO...
[Re: seventy]
#2019700
02/25/16 08:20 PM
02/25/16 08:20 PM
Posts: 2,464 Sydney,Australia
tex013
Sydney,Australia
I am with TommyD . With my 68 Satellite I have 15x8 with 4.5"BS , fit fine with 275/60R15 . Though I now use 255/70R15 on the street . With 8" wide 4"BS and 275's with 4 guys in car I had to roll fender lip due to rubbing . I also have 15x8.5 with 3 7/8BS , with MT 28x10.5 pro bracket radials it gets a very slight rub up in the wheel well outside , this is racing . 10" need 5.5"BS , a couple friends have this on their Plymouths with 295/50R15 , but there is sometimes a slight rub mostly inner wheel well . The Coronet does fit a 30" tyre easier .
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: skicker]
#2019882
02/25/16 11:58 PM
02/25/16 11:58 PM
mopar346
I'd do the 4.5 with an 8" wheel Mine are 5.5 back on a 9.5 wheel. Just in 17's... Are your springs moved in any? I have a set of 5.25 BS 10s that I cant use on anything cause it hits the springs when running the lugs down. They do have a wide cross section tire on them though.
[Re: mopar346]
#2020065
02/26/16 11:33 AM
02/26/16 11:33 AM
skicker
"The Champ"
"The Champ"
Western Md.
They're not moved in at all. SS springs moved back 3/4" with 1 1/2" lowering blocks. The tread is 9.5 and I think the section width is about 12".
...FAFO...
[Re: seventy]
#2020521
02/27/16 12:32 AM
02/27/16 12:32 AM
mopar346
Gotcha the cross section on the ones I have with the 5.25 back space is 13 and change.
