Clearancing SB for 4" crank and Eagle rods #201834
01/23/09 11:31 AM
01/23/09 11:31 AM
Tulsa, Ok
WadeMetzinger Offline OP
Tulsa, Ok
Where all will I need to clearance the block when running a 4" crank and Eagle rods in a small block. It's a 318 block. I'm guessing the bottoms of the cylinders for the rod bolts and possibly the pan rails?
I've never build a SB stroker so this is new to me, looking for some input.
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
Re: Clearancing SB for 4" crank and Eagle rods [Re: WadeMetzinger] #201835
01/23/09 11:36 AM
01/23/09 11:36 AM
Great White North Werst coast
runya Offline
runya  Offline
The oil pump housing may need it also, I recieved a good tip from this board on making a thin spacer from aluminum to put between the pump and block to push it away far enough, that way to don't have to grind the pump housing.
Re: Clearancing SB for 4" crank and Eagle rods [Re: runya] #201836
01/23/09 11:41 AM
01/23/09 11:41 AM
Tulsa, Ok
Tulsa, Ok
Interesting on the oil pump spacer, I'll have to look into that.
Do you have to do much clearancing on the block or is it just minor and some don't even need it, just asking.
What about the counter weights on the crank, do you have to do any clearancing on the block for them? It's a K1 crank.
Re: Clearancing SB for 4" crank and Eagle rods [Re: WadeMetzinger] #201837
01/23/09 11:44 AM
01/23/09 11:44 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
The bottom of the cylinders.
Re: Clearancing SB for 4" crank and Eagle rods [Re: S/ST 3040] #201838
01/23/09 11:52 AM
01/23/09 11:52 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Alot of you guys take pics of everything, some day
I'll learn to do that also
Re: Clearancing SB for 4" crank and Eagle rods [Re: S/ST 3040] #201839
01/23/09 11:53 AM
01/23/09 11:53 AM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
Wade, if they are I beams it may not need anything done to it.
Re: Clearancing SB for 4" crank and Eagle rods [Re: rt66jim] #201840
01/23/09 11:56 AM
01/23/09 11:56 AM
Tulsa, Ok
Tulsa, Ok
They are H-beams...
Re: Clearancing SB for 4" crank and Eagle rods [Re: WadeMetzinger] #201841
01/23/09 12:00 PM
01/23/09 12:00 PM
runya Offline
runya  Offline
I used a K1 crank and rods, and did have to do some clearancing around the main webs also (very little but did need some).
If I remember right I used 1/16" aluminum under the pump with no gaskets, just make sure the spacer is flat and no burrs.
Re: Clearancing SB for 4" crank and Eagle rods [Re: MR_P_BODY] #201842
01/23/09 12:03 PM
01/23/09 12:03 PM
S/ST 3040 Offline
S/ST 3040  Offline
Not everything!
Pictures save me words.....I don't always articulate my thoughts
so other people understand me. Please, no comments.
Martin CC 2007
Re: Clearancing SB for 4" crank and Eagle rods [Re: S/ST 3040] #201843
01/23/09 12:18 PM
01/23/09 12:18 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Not everything!
Martin CC 2007
Thats the same way I feel.... and it would be alot
easier than trying to spell it all out
Re: Clearancing SB for 4" crank and Eagle rods [Re: MR_P_BODY] #201844
01/23/09 01:34 PM
01/23/09 01:34 PM
Denver CO
bennydodge Offline
bennydodge  Offline
Denver CO
I'm running Eagle H-beams in my 340 stroker. I had to notch the bores but my oil pump cleared just fine(MP high vol., MP 4" cast crank).
73 Challenger 340(416),E-heads, 727, 3.23 SG
2015 Challenger R/T classic B5, wife's car
2010 Ram 3500 Crew Cab SLT dually 4X4
2016 Challenger Hellcat Redline Red A8
Re: Clearancing SB for 4" crank and Eagle rods [Re: bennydodge] #201845
01/23/09 04:04 PM
01/23/09 04:04 PM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
Here is the clearancing that I did.
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
